cc2500 spi interfacing with pic
namiz
PostPosted: Thu Aug 28, 2014 5:12 am     Reply with quote
I need some help from you that am on interfacing the cc2500 with PIC micro controller.
I
have found that, when i write an even no data(eg: 0x02) to a reg,i got output always 0x0F when i read same reg. And when i write an odd no data (eg 0x05 (00000101) ) to a reg, i got output one bit rotated 0x82 (10000010).
Hoping for a reply.
Thanks in Advance.
ezflyr
PostPosted: Thu Aug 28, 2014 6:57 am     Reply with quote
Are you using the CCS 'C' Compiler?
Post the code you've got that shows the problem.
John
namiz
PostPosted: Thu Aug 28, 2014 10:45 pm     Reply with quote
Thank you John for reply.
my code is here. Yes, am using CCS C Compiler.
#include <18F25K20.h>
#fuses   BROWNOUT
#fuses   NOPUT
#fuses   NOPROTECT
#fuses   NOWDT
#fuses   INTRC
#byte SSPSTAT = 0XFC7
#byte SSPBUF = 0XFC9
#byte SSPCON1 = 0XFC6
#byte TRISA = 0XF92
#byte TRISC = 0XF94
#byte ADCON1 = 0XFC1
#bit BF = SSPSTAT.0
#define LED   PIN_B4
#define SS   PIN_C7
#define SDO   PIN_C5
#define SDI   PIN_C4
#use delay(clock=64000000)
#use rs232(baud=115200, xmit=PIN_C6, rcv=PIN_C7,ERRORS,STREAM=Debug,DISABLE_INTS)
//#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7,ERRORS,STREAM=Debug,DISABLE_INTS)
unsigned char val[3]={};
void SPIinit();
void spiwrite(unsigned char data);
unsigned char spiread();
unsigned char spitrfx(unsigned char data);
void WriteReg(unsigned char addr, unsigned char value);
unsigned char ReadReg(unsigned char addr);
main()
int i;
setup_oscillator(OSC_64MHZ);
SPIinit();
SET_TRIS_B( 0x00 );
   fprintf(Debug,"first running****\r\n");
   writereg(0x1B,0x05);
   delay_ms(10);
   val[0]=ReadReg(0x1B);
   delay_ms(2000);
   for(i=0;i<1;i++)
      //val[i] = spiread();
      fprintf(Debug,"val[%d]:%x\r\n",i,val[i]);
   output_bit( SS, 1);
//while(1);
void SPIinit()
TRISC = 0X10;
SSPCON1 = 0X21;
SSPSTAT = 0X00;
SSPBUF = data;
while(BF!=1);
data = SSPBUF;
SSPBUF = data;
while(BF!=1);
return(SSPBUF);
return(SSPBUF);
unsigned char a,b;
  output_bit(SS,0);
  while (input(SDI));
  a=spitrfx(addr);
  delay_ms(10);
  b=spitrfx(value);
  delay_ms(10);
  output_bit(SS,1);
fprintf(Debug,"a=%d, b= %d\r\n",a,b);
unsigned char x,y;
  addr = addr + 0x80;
  output_bit(SS,0);
  while (input(SDI));
  x = spitrfx(addr);
  delay_ms(10);
  y = spitrfx(0);
  delay_ms(10);
  output_bit(SS,1);
fprintf(Debug,"x=%d, y= %d\r\n",x,y);
  return y;
PostPosted: Fri Aug 29, 2014 1:43 am     Reply with quote
If using CCS, use CCS!......
Use the CCS functions for SPI.
Get rid of all your register accesses. They are not needed.
Now the common reason for reading the value 'rotated', is that you are clocking on the wrong edge in the SPI settings.
The cc2500, expects the clock to start low, and for you to read/write on the rising edges of the clock. This is SPI mode 1.
So select with:
#use SPI(MODE=1, SPI1, STREAM=CC2500, baud=8MHz)
And then to send a byte, use:
spi_xfer(CC2500,val_to_send,8);
and to read a byte at the same time, use:
val_returned=spi_xfer(CC2500,val_to_send,8);
Let the compiler do it's job.
namiz
PostPosted: Thu Sep 04, 2014 5:42 am     Reply with quote
I have used ccs functions but still theres same problem.
Now when i read same reg, it shows different values.
I changed the code like this.
#use SPI(MODE=1, SPI1, STREAM=CC2500, baud=8000000)
void WriteRegCCS(unsigned char addr, unsigned char value);
unsigned char ReadRegCCS(unsigned char addr);
main()
int i;
//SPIinit();
TRISC = 0X10;
SET_TRIS_B( 0x00 );
   writeregCCS(0x09,0x04);
   delay_ms(10);
   val[0]=ReadRegCCS(0x09);
delay_ms(2000);
   for(i=0;i<1;i++)
   output_bit( SS, 1);
unsigned char a,b;
  output_bit(SS,0);
  while (input(SDI));
  a=spi_xfer(CC2500,addr,8);
  delay_ms(10);
  b=spi_xfer(CC2500,value,8);
  delay_ms(10);
  output_bit(SS,1);
unsigned char x,y;
  addr = addr + 0x80;
  output_bit(SS,0);
  while (input(SDI));
  x = spi_xfer(CC2500,addr,8);
  delay_ms(10);
  y = spi_xfer(CC2500,0,8);
  delay_ms(10);
  output_bit(SS,1);
  return y;
I got output as
/////// HYPERTERMINAL OUTPUT///////////////////
first running****
a=15, b= 15
x=15, y= 15
val[0]:c6
first running****
a=15, b= 15
x=15, y= -51
val[0]:cd
first running****
a=15, b= 32
x=15, y= -12
val[0]:f4
first running****
a=15, b= 4
x=15, y= -118
val[0]:8a
Thanks in advance..
PostPosted: Fri Sep 05, 2014 2:31 pm     Reply with quote
If you get flaky data, you should suspect if you have the wrong SPI mode.
Download the CC2500 data sheet:
http://www.ti.com/lit/ds/symlink/cc2500.pdf
Look at the SPI timing diagram on page 22. Which edge of SCLK do they
show samples the data, right in the middle of the byte ?
This website shows the clock idle state and the sampling edge for
each mode.
http://www.totalphase.com/support/articles/200349236-SPI-Background#modes
You need to edit this statement and fix the mode:
namiz
PostPosted: Wed Sep 17, 2014 4:45 am     Reply with quote
I have gone through datasheet and
it is understood that.
idle state of sck (ckp) = 0
cke = 1
and sample @ middle of data.
i have changed mode now i got only
0x0F as i read any reg aftr write operation.
Thanks in advance.
namiz
cke = 1
Thanks in advance.
ckielstra
PostPosted: Wed Sep 17, 2014 2:20 pm     Reply with quote
I always forget how to figure out the correct SPI mode and that's why I made a short lookup table:
// SPI modes overview.
// SPI Mode | MOTOROLA | MICROCHIP | CCS                          | Clock line idle | Data clocked in at
//          | CPOL CPHA|  CKP CKE  |                              |                 |
//    0     |  0    0  |   0   1   | SPI_L_TO_H | SPI_XMIT_L_TO_H | low             | low to high edge
//    1     |  0    1  |   0   0   | SPI_L_TO_H                   | low             | high to low edge
//    2     |  1    0  |   1   1   | SPI_H_TO_L                   | high            | high to low edge
//    3     |  1    1  |   1   0   | SPI_H_TO_L | SPI_XMIT_L_TO_H | high            | low to high edge
Howto:
1) Look up the clock level in idle state.
2) Look up if the data is clocked in at the up-going or down-going edge.
3) Find SPI mode in the table.
When I look at page 22 of the referenced datasheet I see:
1) Clock in idle = low
2) Data is clocked in at up-going edge.
==> SPI mode = mode 0
That's different from PCM's example but the same as what you've figured out (CPOL=0, CKE=1), we just don't know if it's the same as what you put down in your program.
jsureshp
CC2500 program with pic
PostPosted: Fri Mar 25, 2016 3:52 am     Reply with quote
Hi Namiz,
Please could you share the working program for CC2500 with PIC.
Suresh
