RS232 receive interrupt issue
mutthunaveen
PostPosted: Sun Aug 24, 2014 8:58 am     Reply with quote
hello board
im getting a wired error on INT_RDA, without any action on rx tx from my serial port in my computer im receiving a interrupt all the time
in my computer im reading "received some data" all the time (even i did not send any data to PIC)
here is my code
#include <16F877a.h>
#device adc=10
#use delay(clock=20000000)
#include <flex_lcd.c>
#int_RDA
void  RDA_isr(void)
   printf("\n\r some data received \n\r");
   printf("\n\r program initiated \n\r");
   enable_interrupts(INT_RDA);
while(1){
PostPosted: Sun Aug 24, 2014 9:01 am     Reply with quote
ASSUMING this is REAL hardware and NOT a 'simulation'.....
Do you have a MAX232 or equal between the PIC and PC ?
Also, you should NOT be printing 'inside' the ISR. Instead, set a flag within the ISR and in main check to see if set.
hth
jay
ezflyr
PostPosted: Sun Aug 24, 2014 9:42 am     Reply with quote
This has been covered hundreds of times before. You MUST actually read the received character inside the ISR to clear the int rda interrupt. Add the following to your ISR:
Char Temp;
Temp=getc();
John
PostPosted: Mon Aug 25, 2014 2:49 am     Reply with quote
As Ezflyr says, has been covered multiple times.
However I'll just expand a fraction further.
Key is to understand 'what' the interrupt says.
INT_RDA, is triggered when 'there is a character waiting to be read'.
Now you can clear INT_RDA fine, (the compiler does this for you, when you exit the handler), but since there is still a 'character waiting to be read', it will set again immediately (actually at the start of the instruction after the clear).
You need to distinguish between interrupts that happen at a 'moment', like 'INT_EXT', which occurs when the input signal 'moves through a particular level' (high to low, or low to high), and interrupts that are triggered by a condition or mis-match (INT_RDA, INT_RB, INT_TBE etc..). The latter, require the condition/mis-match to be 'handled' before they are cleared, or they will trigger again, until this is dealt with....
So for INT_RDA, you have to read the byte waiting. For INT_RB, you need to read/write the port, to reset the latches here, for INT_TBE, you need to load a byte into the transmit buffer, etc. etc..
It is in the data sheet, for the peripherals concerned.
mutthunaveen
thanks for your help board
PostPosted: Mon Aug 25, 2014 10:14 pm     Reply with quote
thanks guys...
yes i have MAX IC and now it work Wink
the mistake i made is -> the answer given by ezflyr (thanks man Smile )
thank you Ttelmah for your elaborated information......
now everything works great Very Happy Very Happy
it will be good if they add this information in HELP file of CCS Idea
PostPosted: Tue Aug 26, 2014 12:12 am     Reply with quote
Not really. CCS, expect you to understand the hardware. It's not their job to explain things in this.
mutthunaveen
yes indeed
PostPosted: Tue Aug 26, 2014 10:04 am     Reply with quote
yeah... you are totally correct... its not CCS job.....
CCS would sure help for low hardware knowledge people (like me)
megaball
PostPosted: Wed Sep 25, 2019 5:39 am     Reply with quote
HI,
Can you post all your program?
