XPT2046 Touch Controller
Sterngleiter
PostPosted: Thu Aug 21, 2014 10:53 am     Reply with quote
I need help. I have so bought on ebay a Tft but I do not know how I can control XPT2046. I absolutely do not understand data sheet please help me.
ftp://imall.iteadstudio.com/LCD_Panel/IM120905004/DS_XPT2046.pdf
http://www.ebay.de/itm/3-2-TFT-320-x-240-LCD-Display-Module-with-Touch-Panel-PCB-Adapter-/271233627387?pt=Notebook_Komponenten&hash=item3f26c8b4fb
I have Not any Code
ezflyr
PostPosted: Thu Aug 21, 2014 11:38 am     Reply with quote
Did you see this thread in the forum archives? Was it helpful?
http://www.ccsinfo.com/forum/viewtopic.php?t=48085&highlight=2046
John
Sterngleiter
PostPosted: Thu Aug 21, 2014 11:49 am     Reply with quote
It is Not the same,I need enlightenment, it would be very nice if someone would take
PostPosted: Thu Aug 21, 2014 1:02 pm     Reply with quote
Note: this is a 3Volt device, so choose an 'L' version PIC or at least one that will operate at 3 volts.
That display has both LCD and a touch screen so you need to break your project into two parts.
1) sending data to the LCD. It uses an SSD1289 'controller' chip, so use Google to locate a 'driver' for it. There are several, though I didn't see a CCS C one in the brief time I looked......it does appear to require a 16 bit data bus as the Ebay picture was helpful with the pinout.
this link....
http://320volt.com/en/ts8001-tft-grafik-glcd-ornegi-pic18f4680-ccs-c/
... may be useful, appears to be a good starting point ?
2) sending touchscreen data to the PIC. This LCD uses SPI to communicate to the touchscreen peripheral. Again let Google be your friend and locate a driver.
Without having a unit here, I can't code a driver for it, as I have no way of testing it. I strongly suggest getting #1 done first, sending data to the LCD.
hth
jay
PostPosted: Thu Aug 21, 2014 3:01 pm     Reply with quote
The simple rule to prevent this pain, is don't buy something unless you
have a driver for it ahead of time. Or at least, you must have a good
example driver that can easily be converted to CCS.
KansaiRobot
PostPosted: Wed Nov 25, 2015 12:33 am     Reply with quote
I know this is old, but when you say "driver" you mean the software to control the driver , right?
XPT2046 is just SPI. So if you write SPI code it is supposed to work.
(I say supposed because right now, my code is not working Embarassed )
Should I start a new thread? (because it is about this very same controller I thought maybe this thread would be ok
PostPosted: Wed Nov 25, 2015 1:21 am     Reply with quote
Yes, by 'driver', I meant a software driver (source code).
A new thread for your problem would be better.
