A better substitute for bit_set, bit_clear
notbad
PostPosted: Fri Jul 11, 2014 10:11 am     Reply with quote
Is there a function or a macro to write a Boolean variable to a bit in another variable? If not, how can I write one?
like this:
a.7 = f_boolean();
or
func(a , 7 ,f_boolean());
asmboy
PostPosted: Fri Jul 11, 2014 10:40 am     Reply with quote
two instances of what you ask for come to mind:
a bit that has the same offset in it's home byte
or
an arbitrary offset in the register/byte?
and what's the problem with the ccs function?
notbad
PostPosted: Fri Jul 11, 2014 1:31 pm     Reply with quote
Thanks for your answer asmboy.
arbitrary offset is what I need.
Nothing. I just wanted to be able to assign the return value of a Boolean function to a bit without having to use "if else".
asmboy
PostPosted: Fri Jul 11, 2014 1:58 pm     Reply with quote
check your .LST file
when assigning to a defined bit , it won't get more efficient than
a.7 = whatever_1bit_value
as the compiler dos a pretty slick job with it.
Recall that the only PIC opcodes (16f/18f)
are BCF/BSF and their matching branch-tests.
you are stuck with bit level compares and set/clr
OR a more elaborate AND/OR masking process that
i estimate will take more cycles than just IF/ELSE type code.
PostPosted: Fri Jul 11, 2014 2:09 pm     Reply with quote
It does ? This doesn't even compile:
int8 a;
a.7 = 1;
asmboy
PostPosted: Fri Jul 11, 2014 2:16 pm     Reply with quote
int8 a;
#bit mine a.7
mine = 1;
which we all know is an efficient way to do it-
i'm guessing that's what he intended Question
PostPosted: Fri Jul 11, 2014 2:40 pm     Reply with quote
Why not just #define the test?.
#define bit(v,x,n) if(n) bit_set(v,x); else bit_clear(v,x)
//then use as:
   int val;
   bit(val,7,func());
//assigns the true/false return from func, to bit 7 in val.
Using a union/structure is the another choice:
   struct bits
       int8 b0:1;
       int8 b1:1;
       int8 b2:1;
       int8 b3:1;
       int8 b4:1;
       int8 b5:1;
       int8 b6:1;
       int8 b7:1;
      union
      int i;
      struct bits b;
   } val;
   //val.b.b0 to 7 are the bits, and val.i, the whole integer
   val.b.b0=func();
Or you can generate #bit defines for the bits in a variable, and use these exactly as you show.
notbad
PostPosted: Fri Jul 11, 2014 3:31 pm     Reply with quote
Thanks guys
Ttelmah's first solution is exactly what I was looking for.
Thanks Smile
PostPosted: Fri Jul 11, 2014 4:45 pm     Reply with quote
Sometimes I use a combination of both of the options that Ttelmah suggested:
typedef struct{
   int8 bit0 : 1;
   int8 bit1 : 1;
   int8 bit2 : 1;
   int8 bit3 : 1;
   int8 bit4 : 1;
   int8 bit5 : 1;
   int8 bit6 : 1;
   int8 bit7 : 1;
} bits_t;
#define bit(var,offset) ((bits_t)var).bit##offset
Then calls are just:
bit(test,1) = 1;
It provides the nice macro simplicity look/use, but with the optimized code of the union (no if/else checking)
PostPosted: Sat Jul 12, 2014 12:58 am     Reply with quote
You still have the if/else checking.
It is the only way to do the bit operations with the instruction code.
The point is that the checking is only generated, if the value being written is a variable (return from a function etc.).
The same is true with the original macro version (the compiler optimiser knows to remove the test if the value is fixed).
On the PIC24/30, the if/else, and the structure macro will work, but Jeremiah's version has to be changed to use an 'int', rather than an int8, and the extra 8 bits have to be added for the high byte, otherwise the compiler will give an error.
I too like this approach, and ran into the problems when shifting to a PIC24....
PostPosted: Sat Jul 12, 2014 9:19 am     Reply with quote
Yep, my mistake. I assumed since the decision was actually placed in the macro itself that it wouldn't optimize it out. I should have checked first. That's good to know for the future though.
PostPosted: Sat Jul 12, 2014 11:05 am     Reply with quote
Just occasionally the optimiser is quite smart!... Smile
