nilsener
| 18F2523 and PWM with CCP2 Module |
Posted: Fri Jul 11, 2014 7:31 am |
18F2523
PCWH 4.014
Dear,
I have a PWM signal at CCP1 Pin (RC2) that is running very well. To set the PWM, I use:
setup_timer_2(T2_DIV_BY_4, 255, 1);
setup_ccp1(CCP_PWM);
set_pwm1_duty(value);
Now I want to add an other PWM (with same frequency) on CCP2 Pin (RC1) but it fails. I want to use:
setup_ccp2(CCP_PWM);
set_pwm2_duty(value);
but the compiler says "Undefined identifier set_pwm2_duty" and "Undefined identifier setup_ccp2".
Somebody with an idea how to activate PWM at CCP2 pin?
Thanks for any help
Nilsener |
Posted: Fri Jul 11, 2014 8:09 am |
I'd have to say 'get a new compiler'.
4.014, was when V4, was still beta at best. It was something like 4.050 before it started to work even remotely 'right'.
I kept 3.249, then the next one I felt worth retaining was in the high .060's for V4...
For many months, there was a 'sticky' at the top of this forum as people tried the new releases, and found successive problems. |
Posted: Sun Jul 13, 2014 4:27 pm |
Here's a work-around if you don't want to upgrade. You should upgrade
because 4.014 isn't a great version, but if you don't want to, this will help.
Since setup_ccp2() and set_pwm2_duty() don't exist in vs. 4.014 for
the 18F2523, I just copied the ASM code and put it in a macro wrapper.
I included the feature of 8/10-bit pwm selection by checking the size of the
input parameter in the macro.
There is demo code to ramp the PWM duty cycle from 0 to 100% for both
8 and 10 bit modes. I didn't have an 18F2523 to test it, so I used an
18F4431 which is in the same family. It works. I did test it with vs. 4.014.
My goal was to get ASM code that looked the same as the CCS library
code. The demo shows PWM channels 1 and 2 so you can compare the
library code PWM (used on ch 1) to the macro code on ch 2. They produce
identical waveforms.
#include <18F2523.h>
#fuses INTRC_IO, BROWNOUT, PUT, NOWDT
#use delay(clock=4M)
// This macro creates the set_pwm2_duty() function
// which doesn't exist in vs. 4.014 for the 18F2523.
#byte CCPR2L = 0xFBB
#byte CCPR2H = 0xFBC
#byte CCP2CON = 0xFBA
int16 duty;
int8 temp;
#define BYTE_PTR(x) &(int8 *)(x)
#define set_pwm2_duty(value) \
duty = value; \
if(sizeof(value) == 1) \
CCPR2L = duty; \
else \
#asm \
RRCF BYTE_PTR(duty)+1,F \
RRCF duty,F \
RRCF duty,F \
MOVFF 01,CCPR2L \
RRCF BYTE_PTR(duty)+1,W \
ANDLW 30 \
MOVWF temp \
MOVF CCP2CON,W \
ANDLW 0xCF \
IORWF temp,W \
MOVWF CCP2CON \
#endasm \
// This macro creates the setup_ccp2() function which
// doesn't exist in vs. 4.014 for the 18F2523.
#define setup_ccp2(mode) \
output_low(PIN_C1); \
CCP2CON = mode
int8 duty8;
int16 duty16;
int16 i;
// Back off the PR2 value to 254 so we can get 100% duty cycle.
setup_timer_2(T2_DIV_BY_4, 254, 1);
// Ramp the duty cycle from 0 to 100% for 10-bit and 8-bit pwm.
// 10-bit pwm
for(i = 0; i < 1024; i++)
duty16 = i;
set_pwm1_duty(duty16);
set_pwm2_duty(duty16);
delay_ms(10);
delay_ms(5000);
// 8-bit pwm
for(i=0; i < 256; i++)
duty8 = (int8)i;
set_pwm1_duty(duty8);
set_pwm2_duty(duty8);
delay_ms(50);
