PIC24FJ64GA004 using AN4 as an analog
fuxafak
PostPosted: Tue Jul 08, 2014 10:38 am     Reply with quote
I want to use 23rd pin as an analog input.
I did use analog input with AN0 before. But this pin always return zero analog value.
I think it is about I2C.
Do you have any idea about it.
Datasheet says it has both Analog level input/output and I2C/SMBUS input buffer. In my opinion, i couldn't change this pin to analog.
-ufuk safak-
Istanbul Technical University
drh
PostPosted: Wed Jul 09, 2014 8:01 am     Reply with quote
Page 219 of the datasheet explains how to configure the ADC.
David
fuxafak
PostPosted: Wed Jul 09, 2014 8:19 am     Reply with quote
Here is my config code:
//!   setup_comparator(0x0003);
//!   setup_vref(false);
//!   setup_adc_ports(sAN4, VSS_VDD);
//!   setup_adc(ADC_CLOCK_INTERNAL | ADC_TAD_MUL_31);
   setup_adc(ADC_CLOCK | ADC_TAD_MUL_16);
   set_adc_channel(5);
   //delay_us(10);
And adc sampling code:
      if(adc_flag)
         read_adc(ADC_START_ONLY);
         printf("started");
         int1 done = adc_done();
         while(!done) {
            done = adc_done();
         printf("done");
         x = read_adc(ADC_READ_ONLY);
         printf("\n adc: %u",x);
         adc_flag=0;
There could be problem about comparator module. AN4 is also C1IN- pin and when i use AN5 (which is C1IN+ pin) it works.
.................... //!   setup_comparator(0x0003);
.................... //!   setup_vref(false);
....................     setup_comparator(NC_NC_NC_NC);
1D6A:  CLR     630
Here asm code. When i use setup_comparator for all not connected, it clear CMCON register. When all bits of CMCON goes zero,
bit 1 C1NEG: Comparator 1 Negative Input Configure bit
1 = Input is connected to VIN+
0 = Input is connected to VIN-
Figure 22-1 for the Comparator modes.
bit 0 C1POS: Comparator 1 Positive Input Configure bit
0 = Input is connected to CVREF
See Figure 22-1 for the Comparator modes.
C1- connects to VIN- and C1+ connects to CVref. When C1EN is low, comparator should be off, but is it can be problem about C1- pin configuration.
Please help Smile I am so confused
-ufuk safak-
fuxafak
PostPosted: Wed Jul 09, 2014 8:22 am     Reply with quote
By the way, AN4 is sda and AN5 is scl for i2c module. Is it relevant ?
-ufuk safak-
PostPosted: Wed Jul 09, 2014 8:30 am     Reply with quote
AN0 = adc channel 0
AN4 = adc channel 4 (not 5).....
fuxafak
PostPosted: Wed Jul 09, 2014 8:44 am     Reply with quote
daf--k Smile setup_adc_ports() sets only pin's analog feauture and set_adc_channel() sets the sampling channel. I don't know that i have to use set_adc_channel(), i suppose that it is like STM32 devices. They have a few pin to set ADC but have lots of channel.
Hmm, thanks a lot. Do i have to set channel same as port, right?
-ufuk safak-
PostPosted: Wed Jul 09, 2014 9:03 am     Reply with quote
Yes.
When you configure the ADC, you are saying what AN channels are physically connected to the multiplexer. Then to read a channel, you have to select a connected channel. You are connecting AN4 to the multiplexer, then trying to read AN5, which is not connected. Result nothing....
fuxafak
PostPosted: Wed Jul 09, 2014 5:47 pm     Reply with quote
Yea i understand that Smile sorry for foolish question :p
-ufuk safak-
