Peripheral Pin Select
Torello
PostPosted: Mon Jun 30, 2014 2:37 pm     Reply with quote
Maybe it's late, but I don't get it. One can assign all kinds of IO to
"RPn or RPIn" by like 40+ registers on a Pic24FJ128GC010. Clear.
But ?? how does the RPn or RPIn relate to the actual pins on my pin diagram? They are called in the good old format RA0 up to whatever.
I'm flabbergasted. There must be a simple answer.
Has anyone also a simple code example?
Regards,
Edwin.
Regards, Edwin. PCWHD v5.114
PostPosted: Mon Jun 30, 2014 2:41 pm     Reply with quote
A search here would have found some examples.
You don't use the the RP names at all.
In CCS, you use the function name, and the pin name.
Look at ex_pinselect.c, and ex_pinselect2.c
Torello
PostPosted: Mon Jun 30, 2014 2:43 pm     Reply with quote
Yep... the COMPLETE pin function descriptions. Not listed in the bookmarks and not linked or mentioned in the PPS section. Thank you Microchip
Still, if anyone has an example for me... Very Happy
Torello
PostPosted: Mon Jun 30, 2014 2:48 pm     Reply with quote
Thanks Ttelmah, I'll take a look on mentioned examples.
Btw. I did do several searches on "Peripheral Pin Select". Did not found the obvious you did.
PostPosted: Tue Jul 01, 2014 1:03 am     Reply with quote
If you'd searched on the CCS function name (PIN_SELECT), you'd find lots of threads with the function being used.
Sometimes it is the obvious. Smile
The #PIN_SELECT entry in the manual, also lists most of the function names used.
The problem was trying to be a bit too specific, and including 'peripheral' in the search....
