Possible bug in compiler v5 on PIC24 - float variables
Posted: Sat Jun 21, 2014 1:10 pm
Test done on PIC24FV32KA302.
This simple code was compiled with the version 4 and it has run on the chip correctly, but same code compiled with version 5 return the value two times and cause malfunction of the microcontroller.
The output was read through serial port.
(putting this code into a function)
float res;
res=3.5;
printf("%.2f\r",res); // to serial port
compiled with v4 return -> 3.5
compiled with v5 return -> 3.5
3.5
I have checked also with float variable into a function, the compiler v5 caused that the function is called two times.
Could you confirm it is a bug?
Posted: Sun Jun 22, 2014 8:58 am
Historically, CCS on several compiler versions has had problems with float formats that do not have a field width. So I'm 'not surprised'. It's far safer to specify a width,
vKadal
Posted: Sun Jun 22, 2014 11:24 am
Kindly report this problem to support@ccsinfo.com. Let them also be aware of this problem
