Please help with switch
peterzatko
PostPosted: Fri Jun 20, 2014 11:29 am     Reply with quote
I´m new in programming with C.
I need help with function switch.
My problem :
I have analog input on AN3 (its a 10 bit adc)
I read analog value from 0-1023
If analog value is 1 then variable(d)= 10000
If analog value is 1023 then variable(d)= 50000
If analog value is other(default) then variable(d)= 100000
variable "d" use in my code to change delay_us
i don't know what is wrong in my code!!!!!!
int16 r;
int16 d;
setup_adc_ports(sAN3);
set_adc_channel(3);
delay_ms(10);
while (True)
 r = read_adc();
int r;
switch (r) {
    case 1:d = 10000;break;
    case 1023:d = 5000;break;
    default :d = 100000;break;
   output_high(PIN_A0);
   delay_us(d);
   output_low(PIN_A0);
   delay_us(d);
dyeatman
PostPosted: Fri Jun 20, 2014 12:32 pm     Reply with quote
Things I see, what is the size of r inside the While loop?
Where was it declared?
Don't know if the ADC setup is correct since you don't say what CHIP...
peterzatko
PostPosted: Fri Jun 20, 2014 12:34 pm     Reply with quote
int16 r; //0-65000
dyeatman
PostPosted: Fri Jun 20, 2014 12:36 pm     Reply with quote
What is this?
while (True)
r = read_adc();
int r;    <===============
switch (r) {
peterzatko
PostPosted: Fri Jun 20, 2014 12:44 pm     Reply with quote
i used it .
program nothing do with it or not
gpsmikey
PostPosted: Fri Jun 20, 2014 1:01 pm     Reply with quote
You have two different variables "r" - the one declared in main and the one you declare again AFTER your read the adc. There are two issues - one is that you should only declare variables at the start of a function, not in the middle (I seem to remember hearing cases of CCS getting confused) - the most likely thing is that after you read the ADC, "r" is again declared - not sure what the state of uninitialized variables is, but that may also be causing strange things. You are also trying to declare "r" as both an int16 and an int (which is "int8"). See the data definitions section in the user manual.
mikey
mikey
old engineering saying: 1+1 = 3 for sufficiently large values of 1 or small values of 3
ezflyr
PostPosted: Fri Jun 20, 2014 1:15 pm     Reply with quote
In addition to the things already mentioned, your code strategy is really flawed. For example, expecting the A/D result to be exactly 1 or exactly 1023 is pretty unrealistic. Do something like this instead:
case (r < 10):
    d = 10000;
case (r > 1010):
    d = 5000;
John
peterzatko
PostPosted: Fri Jun 20, 2014 3:01 pm     Reply with quote
i use these
ezflyr wrote:
case (r < 10):
    d = 10000;
case (r > 1010):
    d = 5000;
John
bkamen
PostPosted: Fri Jun 20, 2014 4:04 pm     Reply with quote
ezflyr wrote:
case (r < 10):
    d = 10000;
case (r > 1010):
    d = 5000;
Does that even work in C?
I'm looking at my old K&R C and it states "const expr" for case.
I would just use IF's.
if (r <  10) {
   r = some value;
} else if (r > 1010) {
  r = some value;
Dazed and confused? I don't think so. Just "plain lost" will do. :D
peterzatko
PostPosted: Sat Jun 21, 2014 12:59 am     Reply with quote
i need about 60 case
bkamen wrote:
ezflyr wrote:
case (r < 10):
    d = 10000;
case (r > 1010):
    d = 5000;
if (r <  10) {
   r = some value;
  r = some value;
peterzatko
PostPosted: Sat Jun 21, 2014 1:05 am     Reply with quote
if i compile writte error expression must evaluate to a constant
bkamen wrote:
ezflyr wrote:
case (r < 10):
    d = 10000;
case (r > 1010):
    d = 5000;
if (r <  10) {
   r = some value;
  r = some value;
