12F683 PWM does not work!
40inD
PostPosted: Fri May 16, 2014 1:29 am     Reply with quote
Why the PWM function does not work? No output impulses - just logic 1 always:
#include <12F683.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOCPD                    //No EE protection
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES NOPUT                    //No Power Up Timer
#FUSES BROWNOUT                 //Reset when brownout detected
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
{ int16 adcval;
  int16 rawadc;
   setup_oscillator(OSC_4MHZ);
   setup_adc_ports(sAN3|VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_64);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DIV_BY_1,32,1); // PWM 30.3 kHz <=== correct?
   setup_ccp1(CCP_PWM);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   set_adc_channel(3);
   while (true)
    {adcval=read_adc();
     rawadc=adcval*132/255;
    //set_pwm1_duty(adcval);
    set_pwm1_duty(412); // for test   - not working too
    delay_ms(1);
rikotech8
PostPosted: Fri May 16, 2014 5:03 am     Reply with quote
32 means perod ((4/4000 000)*32=32uS) of the timer_2 overflow. So your PWM's frequency would be 1/(32*10^-6) or 31250Hz.
So the timer_2 register value is compared (each incrementation) to the period specified inside setup_timer_2, if match occurs, the pwm output goes low.
Since the PWM duty register is 10 bits long, only the 8 MSb are compared to the TMR2 register, wich means 255_TMR2 corespond to 1020_DUTY.
So try with set_pwm1_duty(64); // for test
A person who never made a mistake never tried anything new.
PostPosted: Fri May 16, 2014 10:32 am     Reply with quote
Not quite...
Need to use:
set_pwm1_duty(64L);
Note the 'L'.
Some more comments.
The count on the PWM, is from 0, to PR2. So is PR2+1. So the timing is actually 4000000/(4*33) Hz. 30303Hz.
The point being made is that the maximum value you can use in the period is always ((PR2+1)*4)-1 - using a long for the value.
So with 32 selected the PWM range is 0 to 131. Half scale is then 66.
