Can i connect a pot directly without ADC to 16F877a to read?
uma
PostPosted: Sat May 03, 2014 2:09 am     Reply with quote
Can i connect a potentiometer directly without ADC to 16F877a to read the values directly ? Pls reply soon. waiting for it. I want to connect the pot as Analog Input.
uma
Application Engineer,
ETPL
Mike Walne
PostPosted: Sat May 03, 2014 3:53 am     Reply with quote
The '877A PIC has a built in ADC.
Read the data sheet to find out which pins you can use as analogue inputs.
Mike
PostPosted: Sat May 03, 2014 5:15 am     Reply with quote
As Mike says, The 877 does have several inputs to the ADC however if none are available there is a method of using a digital I/O pin to read analoque voltages. You'll have to probably use Google to locate the method. I can't show you my CCS C code for it as that was 14 years ago when I did it!
hth
jay
asmboy
PostPosted: Sat May 03, 2014 2:24 pm     Reply with quote
as a rule of thumb:
the resistance of the pot - end to end must be NO greater than Twice the MINIMUM specified source impedance for accurate ADC reading.
so for a given PIC with a 5k ohm source minimum a 10k pot is as HIGH in value as you dare go.
assuming one end of pot is at Vcc and the other at ground.
PostPosted: Sat May 03, 2014 2:33 pm     Reply with quote
You can also cheat another way.
This chip has a programmable Vref, feeding the comparator. Only a handful of lines of code to simulate a 16 level ADC with this.
uma
PostPosted: Tue May 06, 2014 12:30 am     Reply with quote
thanks for your responses guys,i was busy a little with other project,hence took a gap in this project.I will come back again with my queries after creating and testing my model.
uma
ETPL
