Reg: Same pin for Input and Output
evaradharaj
PostPosted: Thu Apr 24, 2014 9:50 am     Reply with quote
I am using 16f877a for interfacing 4 wire resistive touch screen directly. I am following the instructions from this website:
http://www.pyroelectro.com/tutorials/touchscreen_interface_resistive/img/schematic.png
According to the diagram, I want to configure the port C pins for input as well as output in same program, but in different places (one by one).. Is it possible to do that?
Please suggest me. Thanks
embedding innovation in engineers
PostPosted: Thu Apr 24, 2014 9:56 am     Reply with quote
Yes.
Output_drive sets the pin as an output.
Output_float sets it as an input.
If you are using standard_io, whenever you send data out of a pin, it is set as output, as soon as you read it, it switches to input.
However with the above two drive/float instructions, you can leave the output latch 'set', and disable the drive, as separate operations.
evaradharaj
PostPosted: Thu Apr 24, 2014 7:44 pm     Reply with quote
Thanks Ttelmah.
