Re: Questions about TIMER1 and interrupts
John D. Wilkinson
PostPosted: Wed Nov 07, 2001 2:32 am     Reply with quote
All,
I am still a bit confused as to the correct operation
of TIMER1 and the overflow interrupt.
Given a 16f876 with a 20mhz clock.
TIMER1 is setup as follows:
setup_timer_1(T1_INTERNAL);
Am I correct to assume the following:
1. TIMER1 will increment its count
every (1 / (20000000 / 4)) = .2uSec.
2. TIMER1 will interrupt on overflow
every (.0000002 x 65536) = 0.0131072 seconds.
3. get_timer1() will retrieve the current
TIMER1 accumulated tick count as a 16 bit number.
4. this tick count can range 0-65536 and represents
an actual time of 0-0.0131072 seconds.
If I want to accumulate a long running total of
elapsed time between 2 events can I:
1. Keep track of the number of times TIMER1 overflows.
2. Multiply this overflow count x 0.0131072(time required
for TIMER1 to overflow).
3. Read the current tick count with get_timer1().
4. Multiply this tick count x 0.0000002(time between
increments of TIMER1).
5. Add result from #2 to result from #4 to get the total accumulated elapsed time.
for example:
#int_timer1
timer1_isr()
ulNumOverFlows++;
if(ulNumOverFlows == 1000)
boolOutOfRange = true;
main()
// wait for first event
while(!event1)
// reset TIMER1 internal count
set_timer1(0);
// wait for second event
while(!event2)
// calculate elapsed time between event1 and event2
// read current tick count from TIMER1
// each tick count will represent .2 uSecs
ulEvent2WaitCount = get_timer1();
// add overflow time to current tick count
// to get true elapsed time
float fElapsedTime = (float)(ulNumOverFlows) *
(float) 0.0131072 +
(float)(ulEvent2WaitCount) *
(float) 0.0000002;
Am I somewhere in the ballpark ???
Any comments or alternate suggestions would be greatly appreciated.
Thanks,
John
Original Post ID: 996
Tomi
PostPosted: Sat Nov 10, 2001 2:06 am     Reply with quote
Your basic concept is OK, but you have choose a difficult solution. Let's simplify your conditions.
If you have a 32-bit variable (I assume you use V3 compiler) to hold the elapsed clock periods then we can say that the content of the var. is the (elapsed time in microseconds)*5 Don't use a lot of float calculations: it is a RAM-and ROM-expensive method.
Try this:
int32 elapsedTime; // var. for elapsed time in 0.2 usec steps
#int_timer1
void __Timer1()
int16 upperhalf;
elapsedTime += 0x00010000; // don't worry: it is a simple 16-bit addition to increment the upper 16 bits of the 32-bit var
upperhalf = (int16)(elapsedTime >> 16); // check for timeout
if (upperhalf == 1000) boolOutOfRange = true;
In your main():
float fElapsed;
enable_interrupts(GLOBAL); // you MUST enable global, too
while (!Event1) ;
Set_Timer1(0);
elapsedTime = 0;
while (!Event2) ;
disable_interrupts(INT_TIMER1); // to fix the upper 16 bit of elapsedTime
elapsedTime |= Get_Timer1(); // get the lower half of the 32-bit var
fElapsed = elapsedTime;
fElapsed /= 5000000.0; // to calc. seconds as float
elapsedTime /= 5; // to get time as microseconds
:=All,
:=I am still a bit confused as to the correct operation
:=of TIMER1 and the overflow interrupt.
:=Given a 16f876 with a 20mhz clock.
:=TIMER1 is setup as follows:
:=setup_timer_1(T1_INTERNAL);
:=enable_interrupts(INT_TIMER1);
:=Am I correct to assume the following:
:=1. TIMER1 will increment its count
:=every (1 / (20000000 / 4)) = .2uSec.
:=2. TIMER1 will interrupt on overflow
:=every (.0000002 x 65536) = 0.0131072 seconds.
:=3. get_timer1() will retrieve the current
:=TIMER1 accumulated tick count as a 16 bit number.
:=4. this tick count can range 0-65536 and represents
:=an actual time of 0-0.0131072 seconds.
:=If I want to accumulate a long running total of
:=elapsed time between 2 events can I:
:=1. Keep track of the number of times TIMER1 overflows.
:=2. Multiply this overflow count x 0.0131072(time required
:=for TIMER1 to overflow).
:=3. Read the current tick count with get_timer1().
:=4. Multiply this tick count x 0.0000002(time between
:=increments of TIMER1).
:=5. Add result from #2 to result from #4 to get the total accumulated elapsed time.
:=for example:
:=#int_timer1
:=timer1_isr()
:= ulNumOverFlows++;
:= if(ulNumOverFlows == 1000)
:= boolOutOfRange = true;
:=main()
:= setup_timer_1(T1_INTERNAL);
:= enable_interrupts(INT_TIMER1);
:= // wait for first event
:= while(!event1)
:= // reset TIMER1 internal count
:= set_timer1(0);
:= // wait for second event
:= while(!event2)
:= // calculate elapsed time between event1 and event2
:= // read current tick count from TIMER1
:= // each tick count will represent .2 uSecs
:= ulEvent2WaitCount = get_timer1();
:= // add overflow time to current tick count
:= // to get true elapsed time
:= float fElapsedTime = (float)(ulNumOverFlows) *
:= (float) 0.0131072 +
:= (float)(ulEvent2WaitCount) *
:= (float) 0.0000002;
:=Am I somewhere in the ballpark ???
:=Any comments or alternate suggestions would be greatly appreciated.
:=Thanks,
:=John
Original Post ID: 1046
