		| Author | Message |
		| sshahryiar
				| PCF8574 I2C 8-bit Port Expander Driver |
				|  Posted: Wed Apr 10, 2013 10:37 pm |   |
				| PCF8574.c
  	  | Code: |  	  | #define PORT_BASE_ADDRESS 0x40
 unsigned char read_from_port();
 void write_to_port(unsigned char data_byte);
 unsigned char port_byte=0;
 i2c_start();
 i2c_write((PORT_BASE_ADDRESS + 1));
 port_byte=i2c_read(0);
 i2c_stop();
 return port_byte;
 i2c_start();
 i2c_write(PORT_BASE_ADDRESS);
 i2c_write(data_byte);
 i2c_stop();
 https://www.facebook.com/MicroArena
 SShahryiar
		| fkl
				|  Posted: Mon Apr 29, 2013 3:09 pm |   |
				| Please tell me, I have a PCF8574А respectively doing adjustments
  	  | Code: |  	  | #define PORT_BASE_ADDRESS 0x70 //A1=A2=A3=connect to GND
 does not work
		| sshahryiar
				| Regarding device address. |
				|  Posted: Mon Apr 29, 2013 11:22 pm |   |
				| The first four bits of the device are fixed and so it is not possible to assign a address value of 0x70. If A2, A1 and A0 are connected to ground the legitimate address for PCF8574 is 0x40 and definitely not 0x70. _________________
 SShahryiar
		| fkl
				| Re: Regarding device address. |
				|  Posted: Tue Apr 30, 2013 8:11 am |   |
				|  	  | sshahryiar wrote: |  	  | The first four bits of the device are fixed and so it is not possible to assign a address value of 0x70. If A2, A1 and A0 are connected to ground the legitimate address for PCF8574 is 0x40 and definitely not 0x70. |
 PCF8574A
 error in hw (; PCF8574A was broken.
		| sshahryiar
		| fkl
				|  Posted: Tue Apr 30, 2013 1:29 pm |   |
				|  	  | sshahryiar wrote: |  	  | What do you mean by "Error in HW"? |
 faulty PCF8574A
 Another PCF8574A set and working.
		| sshahryiar
		| kaiyara
				|  Posted: Thu Jul 04, 2013 6:27 am |   |
				| Thanks for sharing your code. It would have been nice when you made more clear that your code only differs from the original version in the part where your code is 12hrs with AM/PM support where the original is 24hrs.
 Also, why did you delete all the comments from the original version? Now your code is more difficult to understand.
 Kai-banned-yara
		| sshahryiar
				| Port expander or RTC? |
				|  Posted: Thu Jul 04, 2013 10:09 am |   |
				| Firstly this post was about PCF8574 port expander and not about any RTC.
 Secondly neither I know about any original code you are talking about nor have I copied anything from somewhere else. Whatever I did and posted here is completely by my own. You may feel similarities with other codes but since they all do the same tasks, they are ought to be similar, but not exactly the same.
 SShahryiar
