MCP3201 12-bit SPI ADC Driver
sshahryiar
PostPosted: Mon Apr 08, 2013 11:15 pm     Reply with quote
#include <16F87.h>
#device *= 16
#fuses NOWDT, INTRC, PROTECT, CPD, PUT, NOWRT
#fuses NOMCLR, BROWNOUT,  FCMEN, NOIESO, NOLVP
#use delay (clock = 4MHz)
#use SPI(MASTER, DI = PIN_A1, CLK = PIN_A2, BITS = 16, MODE = 0)
#define CS        pin_A0
#include <lcd420.c>
void setup();
    register float v = 0.0;
    register unsigned long adc_value = 0;
    setup();
        output_low(CS);
        adc_value = spi_xfer(0);
        output_high(CS);
        adc_value &= 0x1FFE;
        adc_value >>= 1;
        v = (adc_value * 5.0);
        v /= 4095.0;
        lcd_gotoxy(1,1);
        printf(lcd_putc, "V: %1.3f Volt ", v);
        lcd_gotoxy(1,2);
        printf(lcd_putc, "ADC: %4lu ", adc_value);
void setup()
    setup_oscillator(OSC_4MHZ);
    disable_interrupts(global);
    setup_WDT(WDT_off);
    setup_CCP1(CCP_off);
    setup_SPI(SPI_disabled);
    setup_timer_0(0 | 0 | 0);
    setup_timer_1(T1_disabled);
    setup_timer_2(T2_disabled, 255, 1);
    set_timer0(0);
    set_timer1(0);
    set_timer2(0);
    output_high(CS);
    lcd_putc("\f");
https://www.facebook.com/MicroArena
SShahryiar
ihsanbu
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
Can we use this driver for MCP3909
PostPosted: Fri Nov 08, 2013 5:03 am     Reply with quote
ihsan ullah khan
Embedded Designer Since 2003
sshahryiar
PostPosted: Fri Nov 08, 2013 9:07 am     Reply with quote
May be not because both chips are not same....
SShahryiar
