USB Gamepad with 5 buttons
zlittell
PostPosted: Wed Feb 08, 2012 5:37 pm     Reply with quote
I am trying to program my device to be a 5 button (on/off) gamepad. I cannot get the descriptor correct. I get Error 10 Device Cannot Start. I think my problem is with USB_CONFIG_DESC[] and USB_DEVICE_DESC[]. I have not changed them from what is in the KB example because I do not know what any of it means I am almost positive that USB_CLASS_SPECIFIC_DESC[] is correct as I have done tons of reading on it and used the software to create it. I just can't find any info on the other two.
If someone could either help me with my code or even just send me some working code so I can dive into and investigate the differences between mine and yours.
#DEFINE __USB_DESCRIPTORS__
#define  USB_CONFIG_PID       0x0666
#define  USB_CONFIG_VID       0x4311
#define  USB_CONFIG_BUS_POWER 100   //100mA  (range is 0..500)
#define  USB_CONFIG_VERSION   0x0100      //01.00  //range is 00.00 to 99.99
//Tells the CCS PIC USB firmware to include HID handling code.
#DEFINE USB_HID_DEVICE  TRUE
#define USB_EP1_TX_ENABLE  USB_ENABLE_INTERRUPT   //turn on EP1 for IN bulk/interrupt transfers
#define USB_EP1_TX_SIZE 8
//Joystick does not need to receive data from computer
//#define USB_EP1_RX_ENABLE  USB_ENABLE_INTERRUPT   //turn on EP1 for IN bulk/interrupt transfers
//#define USB_EP1_RX_SIZE 4
#include <usb.h>
//Custom JOYSTICK Descriptor
   const char USB_CLASS_SPECIFIC_DESC[] =
    0x05, 0x01,                    // USAGE_PAGE (Generic Desktop)
    0x09, 0x04,                    // USAGE (Joystick)
    0xa1, 0x01,                    // COLLECTION (Application)
    0xa1, 0x00,                    //   COLLECTION (Physical)
    0x05, 0x09,                    //     USAGE_PAGE (Button)
    0x19, 0x01,                    //     USAGE_MINIMUM (Button 1)
    0x29, 0x05,                    //     USAGE_MAXIMUM (Button 5)
    0x15, 0x00,                    //     LOGICAL_MINIMUM (0)
    0x25, 0x01,                    //     LOGICAL_MAXIMUM (1)
    0x95, 0x05,                    //     REPORT_COUNT (5)
    0x75, 0x01,                    //     REPORT_SIZE (1)
    0x81, 0x02,                    //     INPUT (Data,Var,Abs)
    0x95, 0x01,                    //     REPORT_COUNT (1)
    0x75, 0x03,                    //     REPORT_SIZE (3)
    0x81, 0x01,                    //     INPUT (Cnst,Ary,Abs)
    0xc0,                          //     END_COLLECTION
    0xc0                           // END_COLLECTION
   //if a class has an extra descriptor not part of the config descriptor,
   // this lookup table defines where to look for it in the const
   // USB_CLASS_SPECIFIC_DESC[] array.
   //first element is the config number (if your device has more than one config)
   //second element is which interface number
   //set element to 0xFFFF if this config/interface combo doesn't exist
   const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP[USB_NUM_CONFIGURATIONS][1] =
   //config 1
      //interface 0
         0
   // this lookup table defines the size of that descriptor.
   const int16 USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[USB_NUM_CONFIGURATIONS][1] =
   //config 1
      //interface 0
         32
///   start config descriptor
///   right now we only support one configuration descriptor.
///   the config, interface, class, and endpoint goes into this array.
   #DEFINE USB_TOTAL_CONFIG_LEN      34 //config+interface+class+endpoint
   const char USB_CONFIG_DESC[] =
   //IN ORDER TO COMPLY WITH WINDOWS HOSTS, THE ORDER OF THIS ARRAY MUST BE:
      //    config(s)
      //    interface(s)
      //    class(es)
      //    endpoint(s)
   //config_descriptor for config index 1
         USB_DESC_CONFIG_LEN, //length of descriptor size
         USB_DESC_CONFIG_TYPE, //constant CONFIGURATION (CONFIGURATION 0x02)
         USB_TOTAL_CONFIG_LEN,0, //size of all data returned for this config      ==2,3
         1, //number of interfaces this device supports       ==4
         0x01, //identifier for this configuration.  (IF we had more than one configurations)      ==5
         0x00, //index of string descriptor for this configuration      ==6
         0x80, //device is powered over usb.  10000000b
         0x32, //maximum bus power required (maximum milliamperes/2)  (0x32 = 100mA)   //8
   //interface descriptor 1 (KEYBOARD)
         USB_DESC_INTERFACE_LEN, //length of descriptor      =9
         USB_DESC_INTERFACE_TYPE, //constant INTERFACE (INTERFACE 0x04)       =10
         0x00, //number defining this interface (IF we had more than one interface)    ==11
         0x00, //alternate setting     ==12
         1, //number of endpoints for this interface  //13
         0x03, //class code, 03 = HID     ==14
         0x00, //subclass code //boot     ==15
         0x00, //protocol code (keyboard)      ==16
         0x00, //index of string descriptor for interface      ==17
   //class descriptor 1  (HID)
         USB_DESC_CLASS_LEN, //length of descriptor    ==18
         USB_DESC_CLASS_TYPE, //dscriptor type (0x21 == HID)      ==19
         0x00,0x01, //hid class release number (1.0) (try 1.10)      ==20,21
         0x00, //localized country code (0 = none)       ==22
         0x01, //number of hid class descrptors that follow (1)      ==23
         0x22, //report descriptor type (0x22 == HID)                ==24
         USB_CLASS_SPECIFIC_DESC_LOOKUP_SIZE[0][0], 0x00, //length of report descriptor            ==25,26
   //endpoint descriptor 1 IN
         USB_DESC_ENDPOINT_LEN, //length of descriptor                   ==27
         USB_DESC_ENDPOINT_TYPE, //constant ENDPOINT (ENDPOINT 0x05)          ==28
         0x81, //endpoint number and direction (0x81 = EP1 IN)       ==29
         USB_ENDPOINT_TYPE_INTERRUPT, //transfer type supported (0x03 is interrupt)         ==30
         USB_EP1_TX_SIZE,0x00, //maximum packet size supported                  ==31,32
         10,  //polling interval, in ms.  (cant be smaller than 10 for slow speed devices)     ==33
   //****** BEGIN CONFIG DESCRIPTOR LOOKUP TABLES ********
   //since we can't make pointers to constants in certain pic16s, this is an offset table to find
   //  a specific descriptor in the above table.
   //NOTE: DO TO A LIMITATION OF THE CCS CODE, ALL HID INTERFACES MUST START AT 0 AND BE SEQUENTIAL
   //      FOR EXAMPLE, IF YOU HAVE 2 HID INTERFACES THEY MUST BE INTERFACE 0 AND INTERFACE 1
   #define USB_NUM_HID_INTERFACES   1
   //the maximum number of interfaces seen on any config
   //for example, if config 1 has 1 interface and config 2 has 2 interfaces you must define this as 2
   #define USB_MAX_NUM_INTERFACES   1
   //define how many interfaces there are per config.  [0] is the first config, etc.
   const char USB_NUM_INTERFACES[USB_NUM_CONFIGURATIONS]={1};
   //define where to find class descriptors
   //first dimension is the config number
   //second dimension specifies which interface
   //last dimension specifies which class in this interface to get, but most will only have 1 class per interface
   //if a class descriptor is not valid, set the value to 0xFFFF
   const int16 USB_CLASS_DESCRIPTORS[USB_NUM_CONFIGURATIONS][1][1]=
   //config 1
      //interface 0
         //class 1
         18
   //****** END CONFIG DESCRIPTOR LOOKUP TABLES ********
   #if (sizeof(USB_CONFIG_DESC) != USB_TOTAL_CONFIG_LEN)
      #error USB_TOTAL_CONFIG_LEN not defined correctly
///   start device descriptors
   const char USB_DEVICE_DESC[] = {
      //starts of with device configuration. only one possible
         USB_DESC_DEVICE_LEN, //the length of this report   ==1
         0x01, //the constant DEVICE (DEVICE 0x01)  ==2
         0x10,0x01, //usb version in bcd (pic167xx is 1.1) ==3,4
         0x00, //class code ==5
         0x00, //subclass code ==6
         0x00, //protocol code ==7
         USB_MAX_EP0_PACKET_LENGTH, //max packet size for endpoint 0. (SLOW SPEED SPECIFIES 8) ==8
         USB_CONFIG_VID & 0xFF, ((USB_CONFIG_VID >> 8) & 0xFF), //vendor id       ==9, 10
         USB_CONFIG_PID & 0xFF, ((USB_CONFIG_PID >> 8) & 0xFF), //product id, don't use 0xffff       ==11, 12
         USB_CONFIG_VERSION & 0xFF, ((USB_CONFIG_VERSION >> 8) & 0xFF), //device release number  ==13,14
         0x01, //index of string description of manufacturer. therefore we point to string_1 array (see below)  ==15
         0x02, //index of string descriptor of the product  ==16
         0x00, //index of string descriptor of serial number  ==17
         USB_NUM_CONFIGURATIONS  //number of possible configurations  ==18
   #if (sizeof(USB_DEVICE_DESC) != USB_DESC_DEVICE_LEN)
      #error USB_DESC_DEVICE_LEN not defined correctly
-zack-
zlittell
PostPosted: Fri Feb 10, 2012 7:44 pm     Reply with quote
Figured it out - forgot to remove the out descriptor for the RX data that was no longer in the HID descriptor. Also forgot to change number of endpoints from like 2 to 1 I am pretty sure.
It is now working. Should have read through the code more carefully I suppose :/
maddyable
PostPosted: Tue Feb 14, 2012 9:57 pm     Reply with quote
The Dual Power PC Gamepad is unique in that it doesn't require a pin-port for installation instead it uses a USB port to connect to your computer.
