problem with config oscillator on pic18f25k80
blo
PostPosted: Tue Apr 19, 2011 3:25 am     Reply with quote
Hi, I'm tryng to use the PIC18f25k80 with the internal oscillator (HF-INTOSC 16MHz) and the PLL enabled for work at 64MHz.
this is my code:
#include <18F25K80.h>
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES VREGSLEEP
#FUSES INTRC_HP
//#FUSES SOSC_HIGH
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES PLLEN
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES BORV18
#FUSES ZPBORM
#FUSES WDT_NOSLEEP
#FUSES WDT1048576
#FUSES MSSPMSK7
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES BBSIZ2K                  //2K words Boot Block size
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
//#FUSES NOPMPEMB //PMP Pins are not on the external memory bus
#use delay (clock=64M)
when I compile I get an error on the #use delay(). The error says:"Option invalid Internal oscillator frequency wrong.
Anybody can help me?
Thank you for the reply
PostPosted: Tue Apr 19, 2011 12:33 pm     Reply with quote
You have multiple oscillator fuses. You should only have one.
#FUSES VREGSLEEP
#FUSES INTRC_HP
//#FUSES SOSC_HIGH
#FUSES PLLEN
#FUSES FCMEN
#FUSES WDT128
#FUSES WDT1048576
You also have multiple Watchdog fuses.
Here is a recent thread on oscillator setup problems with the "K80" family
of PICs. This thread may, or may not help:
http://www.ccsinfo.com/forum/viewtopic.php?t=45164
If you need more help, post your compiler version. We don't remember
your version from previous threads.
blo
PostPosted: Tue Apr 19, 2011 1:06 pm     Reply with quote
thank you for the reply. Tomorrow I will try to fix the problem.
