How do putc() work?
agreement
How do putc() work?
PostPosted: Wed Mar 02, 2011 9:29 pm     Reply with quote
Hi everyone! Although I have look for this function in PICC folder but I can't find this function. Can you tell me how to see inside this function? Thanks!
bkamen
Re: How do putc() work?
PostPosted: Wed Mar 02, 2011 10:55 pm     Reply with quote
Look in the help file Ccsc.chm in your installation folder.
(mine is the default: C:\Program Files\PICC)
putc is easily searched in said file.
-Ben
Dazed and confused? I don't think so. Just "plain lost" will do. :D
PostPosted: Wed Mar 02, 2011 11:04 pm     Reply with quote
To learn how to see the ASM code for putc(), read these threads:
http://www.ccsinfo.com/forum/viewtopic.php?t=22649
http://www.ccsinfo.com/forum/viewtopic.php?t=22149
agreement
PostPosted: Thu Mar 03, 2011 7:35 am     Reply with quote
i see. thanks so much!
tim_sid
PostPosted: Mon Jun 30, 2014 6:11 am     Reply with quote
Hello all,
I used this blocking technique in my code and I want to create blocking putc().
using byte and bit defined for TXIF i added this in my code.
while(TXIF==0);
     putc(packet[k]);
when i disconnect Rx Tx lines, shouldn't it stuck at this? my program goes on running and doesnt block at this point. Please suggest how can I create blocking transmit function.
PostPosted: Mon Jun 30, 2014 7:44 am     Reply with quote
putc, already blocks. It waits if the character can't be accepted by the UART. However the UART will merrily transmit into an open line, so disconnecting the lines won't stop it.
You could make it check for 'line break', by verifying that the RX line is high before sending. This can simply be read as an input.
tim_sid
PostPosted: Tue Jul 01, 2014 12:46 am     Reply with quote
Thanks Ttelmah,
This made some points clear about transmission. I will try it. Thanks.
