Help PIC 16F876 And LCD 16X2
Goto page 1, 2  Next
Rosmaninho
PostPosted: Sun Feb 27, 2011 12:09 pm     Reply with quote
Hi i'm trying to write a program, very simple program:
#include <16F876A.h>
#include <lcd.c>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES
#use delay(clock=20000000)
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(VREF_LOW|-2);
delay_ms(5);   // <----- delays
lcd_putc("\f"); //Clear display
delay_ms(5);
lcd_gotoxy(1,1);
delay_ms(5);
lcd_putc("Champ");  // you want to send this to the lcd only once
// LCD Display //
   printf(lcd_putc, "\f Testing LCD     ");
And when i Compile the program, it give me Error in Source File, LCD.C
1 Errors, 0 Warnings.
Error[12]   C:\Program Files\PICC\drivers\lcd.c 106 : Undefined identifier  -- set_tris_lcd
Can anyone give me a help?
PostPosted: Mon Feb 28, 2011 8:48 am     Reply with quote
You may have a bad lcd.c file as there is no set_lcd_tris in my copy of lcd.c
Rosmaninho
PostPosted: Mon Feb 28, 2011 9:48 am     Reply with quote
That's what i think...
I already change the LCD source file, to "LCD420.c" that was at PICC too, and I resolve it...
Thanks....
PostPosted: Mon Feb 28, 2011 1:23 pm     Reply with quote
It's in lcd.c in vs. 4.119. The Examine32 text search program gives
these results:
c:\program files\picc\drivers\lcd.c
#define set_tris_lcd(x) set_tris_b(x)
set_tris_lcd(LCD_INPUT_MAP);
set_tris_lcd(LCD_OUTPUT_MAP);
It may work, but the lcd.c driver is the best one to use for a 16x2 LCD.
You forgot to put in the #include line for lcd.c. You need to add the line
shown in bold below:
#include <lcd.c>
#device adc=8
#FUSES
#include <lcd.c>
Also you are missing your oscillator fuse. I suspect this is a Proteus project.
Rosmaninho
PostPosted: Mon Feb 28, 2011 4:40 pm     Reply with quote
This is my "LCD.C"
////                             LCDD.C                                ////
////                 Driver for common LCD modules                     ////
////  lcd_init()   Must be called before any other function.           ////
////  lcd_putc(c)  Will display c on the next position of the LCD.     ////
////                     The following have special meaning:           ////
////                      \f  Clear display                            ////
////                      \n  Go to start of second line               ////
////                      \b  Move back one position                   ////
////  lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1)    ////
////  lcd_getc(x,y)   Returns character at position x,y on LCD         ////
////        (C) Copyright 1996,2003 Custom Computer Services           ////
//// This source code may only be used by licensed users of the CCS C  ////
//// compiler.  This source code may only be distributed to other      ////
//// licensed users of the CCS C compiler.  No other use, reproduction ////
//// or distribution is permitted without written permission.          ////
//// Derivative programs created using this software in object code    ////
//// form are not restricted in any way.                               ////
// As defined in the following structure the pin connection is as follows:
//     D0  enable
//     D1  rs
//     D2  rw
//     D4  D4
//     D5  D5
//     D6  D6
//     D7  D7
//   LCD pins D0-D3 are not used and PIC D3 is not used.
// Un-comment the following define to use port B
// #define use_portb_lcd TRUE
struct lcd_pin_map {                 // This structure is overlayed
           BOOLEAN enable;           // on to an I/O port to gain
           BOOLEAN rs;               // access to the LCD pins.
           BOOLEAN rw;               // The bits are allocated from
           BOOLEAN unused;           // low order up.  ENABLE will
           int     data : 4;         // be pin B0.
        } lcd;
#if defined(__PCH__)
#if defined use_portb_lcd
   #byte lcd = 0xF81                   // This puts the entire structure
#else
   #byte lcd = 0xF83                   // This puts the entire structure
#else
   #byte lcd = 6                  // on to port B (at address 6)
#else
   #byte lcd = 8                 // on to port D (at address 8)
//#else
//   #define set_tris_lcd(x) set_tris_d(x) Configurar as portas para o LCD, Alterado por Tony a 27-02-2011
#define lcd_type 2           // 0=5x7, 1=5x10, 2=2 lines
#define lcd_line_two 0x40    // LCD RAM address for the second line
BYTE const LCD_INIT_STRING[4] = {0x20 | (lcd_type << 2), 0xc, 1, 6};
                             // These bytes need to be sent to the LCD
                             // to start it up.
                             // The following are used for setting
                             // the I/O port direction register.
struct lcd_pin_map const LCD_WRITE = {0,0,0,0,0}; // For write mode all pins are out
struct lcd_pin_map const LCD_READ = {0,0,0,0,15}; // For read mode data pins are in
BYTE lcd_read_byte() {
      BYTE low,high;
      set_tris_lcd(LCD_READ);
      lcd.rw = 1;
      delay_cycles(1);
      lcd.enable = 1;
      delay_cycles(1);
      high = lcd.data;
      lcd.enable = 0;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(1);
      low = lcd.data;
      lcd.enable = 0;
      set_tris_lcd(LCD_WRITE);
      return( (high<<4) | low);
void lcd_send_nibble( BYTE n ) {
      lcd.data = n;
      delay_cycles(1);
      lcd.enable = 1;
      delay_us(2);
      lcd.enable = 0;
void lcd_send_byte( BYTE address, BYTE n ) {
      lcd.rs = 0;
      while ( bit_test(lcd_read_byte(),7) ) ;
      lcd.rs = address;
      delay_cycles(1);
      lcd.rw = 0;
      delay_cycles(1);
      lcd.enable = 0;
      lcd_send_nibble(n >> 4);
      lcd_send_nibble(n & 0xf);
void lcd_init() {
    BYTE i;
    lcd.rs = 0;
    lcd.rw = 0;
    lcd.enable = 0;
    delay_ms(15);
    for(i=1;i<=3;++i) {
       lcd_send_nibble(3);
       delay_ms(5);
    lcd_send_nibble(2);
    for(i=0;i<=3;++i)
       lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy( BYTE x, BYTE y) {
   BYTE address;
   if(y!=1)
     address=lcd_line_two;
     address=0;
   address+=x-1;
   lcd_send_byte(0,0x80|address);
void lcd_putc( char c) {
   switch (c) {
     case '\f'   : lcd_send_byte(0,1);
                   delay_ms(2);
     case '\n'   : lcd_gotoxy(1,2);        break;
     case '\b'   : lcd_send_byte(0,0x10);  break;
     default     : lcd_send_byte(1,c);     break;
char lcd_getc( BYTE x, BYTE y) {
   char value;
    lcd_gotoxy(x,y);
    while ( bit_test(lcd_read_byte(),7) ); // wait until busy flag is low
    lcd.rs=1;
    value = lcd_read_byte();
    lcd.rs=0;
    return(value);
I'm not finding the problem, the message:
Error[12]   C:\Program Files\PICC\drivers\lcd.c 93 : Undefined identifier  -- set_tris_lcd
[/code]
PostPosted: Mon Feb 28, 2011 4:44 pm     Reply with quote
What port on the PIC is the LCD connected to ? Is it Port D, or Port B ?
Post a list of the connections between the LCD pins and the PIC pins.
Or post your Proteus schematic on a free image hosting service, and
then post a link to it.
Rosmaninho
PostPosted: Mon Feb 28, 2011 5:39 pm     Reply with quote
Is connected at port B
http://www.e-rosmaninho.com/tese/my.jpg
PostPosted: Mon Feb 28, 2011 5:54 pm     Reply with quote
I didn't notice that you had lcd.c included just below the PIC include line.
It's better if you put it in the location that I show below. But anyway, to
use PortB, you need to add the #define statement for 'use_portb_lcd' just
above the #include line for lcd.c, as shown below in bold:
#device adc=8
#FUSES HS, NOWDT
#include <lcd.c>
Rosmaninho
PostPosted: Mon Feb 28, 2011 6:17 pm     Reply with quote
Thanks, it's working with this last help...
Rosmaninho
PostPosted: Fri Apr 22, 2011 4:09 pm     Reply with quote
hi again.... i'm trying to test the program but the display seems to be dead. don't give me one sign of working....
in proteus, it works....
DISPLAYTECH 162B
LCD connections:
pin 1 -- Resistor---- +5v
pin 2 -- GND
pin 3 -- GND
pin 4 -- 5V
pin 5 -- 5V
pin 6 -- RB1
pin 7 -- RB2
pin 8 -- RB0
pin 9 -- NC
pin 10 NC
pin 11-- NC
pin 12 --NC
pin 13 RB4
pin 14 RB5
pin 15 RB6
pin 16 RB7
can you confirm if that's all ok?
this is my code:
#device adc=8
#include <lcd.c>
//  Variaveis de Apoio
int a;
int b;
int c;
// Guarda Valor do ADC
float valor;
set_adc_channel(0);
setup_adc(  ADC_CLOCK_INTERNAL  );
setup_port_a(ALL_ANALOG); // se port a to all analoges
set_tris_c (0b1111111); //0 - inputs | 1 - outputs
// Inicialização do Display
//lcd_init();
delay_ms(50);   // <----- delays
lcd_putc("\f "); //Clear display
delay_ms(50);
lcd_gotoxy(1,1);
delay_ms(50);
a=0;
// Publicidade
lcd_gotoxy(0,0);
lcd_putc( "\f E. Rosmaninho");
lcd_putc("\n Versao V0.1");
delay_ms(50);
lcd_gotoxy(1,0);
lcd_putc("\b Date 01/03/2011");
delay_ms(50);
lcd_gotoxy(1,0);
lcd_putc("\b Programmer: Tony    ");
delay_ms(50);
valor=0;
while (1) {
   // 1ª Leitura
   delay_ms( 50 );// SCAN TIME PAUSe, desactivado para ser mais rápido na simulação
   lcd_putc( "\f");
   valor = read_adc();
   valor= (2/10.24)*valor;
  // Termoestato Electrónico
   If (valor < 23 )
       output_high(pin_C0);                     // Liga Aquecimento
       b=1; // Variável auxiliar aquecimento
       c=0; // Variável auxiliar alarme
       lcd_gotoxy(1,1);
       printf(lcd_putc,"Set Point: 25 C");
       lcd_gotoxy(1,2);
       printf(lcd_putc,"\nTemp: %.1fC\n", valor);
       delay_ms(100);}
   If (valor > 23 && valor < 27 && b==1 ) // A Aguardar que atinja a temperatura de desligar
       lcd_gotoxy(1,1);
       lcd_gotoxy(1,2);
       printf(lcd_putc,"\n Temp: %.1fC", valor);
       c=0;
   If (valor > 23 && valor < 27 && b==0 ) // Em espera para voltar a ligar
       lcd_gotoxy(1,1);
       lcd_gotoxy(1,2);
       output_low(pin_C1);
       c=0;
       delay_ms(100);} // Desliga o alarme
   If (valor > 27 && valor <40 && c==0) // Desliga o aquecimento
      {output_low(pin_C0);
      b=0;
      lcd_gotoxy(1,1);
      lcd_gotoxy(1,2);
      delay_ms(100);}
    If (valor > 27 && valor <40 && c==1) // Vem de uma situação de alarme
      b=0;
      lcd_gotoxy(1,1);
      printf(lcd_putc, "  !! ALARME !!  ");
      lcd_gotoxy(1,2);
      delay_ms(100);}
   while (valor > 40 ) // situação de alarme
        valor = read_adc();
        output_low(pin_C0);
        output_high(pin_C1);
        b=0;
        c=1;
        lcd_gotoxy(1,1);
        lcd_gotoxy(1,2);
        printf(lcd_putc,"\nTemp: %.1fC", valor);
        delay_ms(10);};
in theory works... in the practice no :( is possible LCD burned?
regards
PostPosted: Fri Apr 22, 2011 4:21 pm     Reply with quote
Proteus doesn't care about a lot of things that are important in real hardware.
#FUSES NOWDT
Where is your oscillator fuse ? HS is needed.
lcd_gotoxy(0,0);
The coordinates origin for the lcd.c driver is (1,1).
This is stated, right in the instructions at top of the driver file. Example:
pin 2 -- GND
pin 3 -- GND
pin 4 -- 5V
pin 5 -- 5V
pin 6 -- RB1
pin 7 -- RB2
pin 8 -- RB0
pin 9 -- NC
pin 10 NC
pin 11-- NC
pin 12 --NC
pin 13 RB4
pin 14 RB5
pin 15 RB6
pin 16 RB7
There are at least two different pinouts for the 162B LCD.
In this one, pins A and K are on pins 15 and 16:
http://www.displaytech-us.com/pdf/FullSpecs/S162B-v11.pdf
In this one, they are on pins 1 and 2:
http://www.astlab.hu/pdfs/162b-series-lcd.pdf
Which one is correct ?
My advice is, get a different brand of LCD than DisplayTech. Get one
that has consistent documentation, where the pinouts are always the same.
Also I just noticed that you're using PortB, but you didn't do the changes
that I said in a previous post. Same with the HS fuse. So I guess I'm done with this.
Rosmaninho
PostPosted: Fri Apr 22, 2011 4:33 pm     Reply with quote
i'm using the second one, the backlight switch in pin1 and 2
PostPosted: Fri Apr 22, 2011 4:42 pm     Reply with quote
You have the Vo pin connected to +5v. That's the LCD contrast pin.
According to the data sheet, it should be set to approximately .2 to .5 volts.
If you set it to +5v, the LCD won't display properly.
pin 2 -- GND
pin 3 -- GND
pin 4 -- 5V
pin 5 -- 5V
pin 6 -- RB1
pin 7 -- RB2
pin 8 -- RB0
pin 9 -- NC
pin 10 NC
pin 11-- NC
pin 12 --NC
pin 13 RB4
pin 14 RB5
pin 15 RB6
pin 16 RB7
Also, if you have an ICD programmer connected to the board, the LCD
won't work. The ICD uses pins B6 and B7.
Rosmaninho
PostPosted: Fri Apr 22, 2011 5:04 pm     Reply with quote
Sorry, what's a ICD programmer?
the PIN 5 I connect to GND, and the display already show anything....
its all ON
Rosmaninho
PostPosted: Fri Apr 22, 2011 5:16 pm     Reply with quote
I see something like this in the 2 lines:
http://bp2.blogger.com/_27zDbRTyMD8/SGmGZ5Yk3UI/AAAAAAAAAMI/oCK_p6PsMkg/s1600-h/29062008227.jpg
Goto page 1, 2  Next
Page 1 of 2
