How can i solve I/O error 103 on the compiler.
juansebmx
PostPosted: Mon Jan 17, 2011 11:44 am     Reply with quote
I Had a problem when i try to compile a program, i already had try to compile the program with the other alternatives on the tab of compile, and it shows a window with the message of "I/O error 103".
Can someone help me with this query, and thanks a lot for your commentaries related to this.
Control, and Robotics.
PostPosted: Mon Jan 17, 2011 3:26 pm     Reply with quote
I/O error, sounds odd. Are you sure you can write to the directories where the code is installed (the compiler needs to do this)?.
In general the first thing to do, is to re-install the compiler, from a clean download, and try a short one of the example programs. If this works, then move to your code.
'Error 103', normally means a numeric value is out of the allowed range (you get this if you try for example to use a switch statement with a value above 65535).
PostPosted: Mon Jan 17, 2011 3:59 pm     Reply with quote
It's a Delphi error code. CCS uses Delphi to write their Windows IDE program:
http://www.ccsinfo.com/forum/viewtopic.php?t=36368
PostPosted: Tue Jan 18, 2011 3:02 am     Reply with quote
Which goes back to my thought about not being able to write to the directory.
A Google on Delphi I/O error 103, suggests it is a common problem with networked drives. It also seems to happen if you have two copies of some programs open 'at once', with a semaphore then not being settable. Also, if the application was installed as 'super user', and then you try to run it, without write permissions.
