Array of functions? Avoiding if's for calling routines
ivaneduardo747
PostPosted: Fri Dec 03, 2010 2:11 pm     Reply with quote
Hello, I'm coding a program that receives a value CMD from the UART (along with other things). I want to call functions depending on the value of CMD. Right now I'm using this:
if (CMD==0) {
    doThis();
else if(CMD==1) {
    doThat();
else if(CMD==2) {
    blahBlah();
which I find very ineffective and hard to code for 256 functions.
Is there any way I could do some kind of array or lookup table where I assign CMD as the pointer and call the instruction?
0x2BE NOR 0X2BE
PostPosted: Fri Dec 03, 2010 2:38 pm     Reply with quote
Is there any way I could do some kind of array or lookup table ?
Array of function pointers:
http://www.ccsinfo.com/forum/viewtopic.php?t=43696
http://www.ccsinfo.com/forum/viewtopic.php?t=37478
This is probably only reliable if you use the PCH compiler (with 18F PICs).
Gabriel
PostPosted: Sat Dec 04, 2010 6:15 am     Reply with quote
use Switch()....
CMD would be the "case"
G.
CCS PCM 5.078 & CCS PCH 5.093
