P18F4550 Changing USB PID and VID
Nicce
PostPosted: Tue Sep 14, 2010 3:35 am     Reply with quote
Hi Guys,
Simple question. Where are the PID and VID defined? I need to change them to a custom PID and VID that our project is using.
Regards,
Nicce
PostPosted: Tue Sep 14, 2010 4:04 am     Reply with quote
In the descriptor file.
In the early USB drivers, they were just 'hard coded' in the descriptor structure, but on the later compilers, there are defines early on the descriptor file, that set these. If (for example), you are using the CDC descriptor, then immediately after the remarks, there is a test for the define __USB_DESCRIPTORS__, and then the PID, VID, BUS_POWER options, and version number are loaded.
Nicce
PostPosted: Tue Sep 14, 2010 4:09 am     Reply with quote
Excellent thanks!
Wayne_
PostPosted: Tue Sep 14, 2010 4:31 am     Reply with quote
Just a word of warning, If you are using the files in the drivers folder I would sugest you make a copy of them in a local folder for your project. if you upgrade the compiler there is a chance you will overwrite the drivers and examples with new versions losing all your changes Smile
PostPosted: Tue Sep 14, 2010 6:48 am     Reply with quote
Yes.
In fact I think the files are written, so if you setup all the descriptors yourself, and define 'USB_DESCRIPTORS', then the CCS defines won't load. This way, you can put all the descriptors in your own file, then include the CCS stuff, and your values override the ones in the CCS files. Downside, is that you have to fill out the entire descriptor entry, not just the VID/PID.
