pic to pic communication using uart
Goto page Previous  1, 2
cheehow
PostPosted: Mon Nov 08, 2010 10:17 am     Reply with quote
HI Everyone!!
I have written the code for this RS485, but in the code, there're required for pin B4 and B5 as RS 485 enable pin. So, in hardware circuit schematics. I don't have any idea to construct about it !! Please give me some guide. Your help would be appreciated!! thxs
Regards
Chee How
PostPosted: Mon Nov 08, 2010 10:14 pm     Reply with quote
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=28442
cheehow
PostPosted: Wed Nov 10, 2010 9:32 am     Reply with quote
HI PCM Programmer,
i have one question. for the RS 232, what is the "stream" for ?? coz i saw some code put
#use rs232 ( baud rate=............, stream=pc);
is it communicate to the destination ? if i wanna communicate with the PIC microcontroller, is it put PIC there ??
Regards,
Chee How
cheehow
PostPosted: Wed Nov 10, 2010 10:24 am     Reply with quote
Sorry for asking question here again ...
Now I meet some problem in the codes. The following are my codes:
Master:
#include <16F877A.h>
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, PUT
#use delay(clock = 20000000)
#use rs232 (baud=9600, xmit=PIN_C6, rcv=PIN_C7, stream=PIC)
#define RS485_ID        0x11
#define RS485_USE_EXT_INT TRUE
#include <RS485.c>
     int data_received;
     rs485_init();
   while(True)
      rs485_wait_for_bus(FALSE);
      if (input(pin_b1))
         rs485_send_message(0x12, 1, 3);
         output_high(PIN_b7);
         output_low(PIN_b7);
       if(rs485_get_message(data_received, FALSE))
               if(data_received==6)
                   output_high(PIN_b6);
                   output_low(PIN_b6);
and the following are the slave codes:
#define RS485_ID  0x12
#include <RS485.c>
     int data_received;
     rs485_init();
     do
         if(rs485_get_message(data_received, TRUE))
          if(dnata_received == 0x12)
            output_high(PIN_B2);
            output_low(PIN_B2);
         if(rs485_send_message(0x11, 1, 6))
               output_high(PIN_B1);
               output_low(PIN_B1);
     while(true);
The problem is I can't detect where is the problem, because my hardware does not work. Can you all please check my codes see whether got any problem or not ... thxsss
My project is just like what I have said in previous, and it still not working. Hope to hear the good news soon. Your help would be appreciated.
Regards
Chee How
PostPosted: Wed Nov 10, 2010 12:46 pm     Reply with quote
output_low(PIN_b7);
output_low(PIN_b6);
You are using pins B6 and B7 for LEDs. These pins are used by the
ICD debugger/programmer. Don't use them for LEDs.
Post a link to a schematic of your hardware connections.
cheehow
PostPosted: Thu Nov 11, 2010 9:27 am     Reply with quote
here is the link for my schematic diagram..
http://www.flickr.com/photos/briansiaw/5167023278/
tzehow_90
View user's profile Send private message Send e-mail MSN Messenger
help
PostPosted: Tue Mar 05, 2013 1:18 pm     Reply with quote
I am new in using uart... can i have the circuit for connection between 2 pic for the coding above.... may i know wat we need to define and include during using uart.... thx very much
Mike Walne
PostPosted: Tue Mar 05, 2013 3:02 pm     Reply with quote
The answer should be an emphatic no.
Mike
Page 2 of 2
