PT2257 audio controller I2C protocol
wangine
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Mon Aug 02, 2010 12:45 pm     Reply with quote
Greeting
Below we have a driver written by me for an IC (volume control)
the SDA / SCL volume control that lets the 79 decades
It is written for two channels simultaneously but can write and balance
// Driver sda/ Scl volum PT2257                               //
// Version 0.1                                                //
// Writer Tanase Bogdan                                       //
// Chip information                                           //
// Pin 1 == Left In                                           //
// Pin 2 == Left Out                                           //
// Pin 3 == VSS                                                //
// Pin 4 == SDA                                                //
// Pin 5 == SCL                                                //
// Pin 6 == VDD (3 to 9V)                                 //
// Pin 7 == Right Out                                        //
// Pin 8 == Right In                                          //
// Require pullup rezistor an SDA/SCL 10k
#define zeci_max 0b11100000
#define zeci_min 0b11100111
#define unit_max 0b11010000
#define unit_min 0b11011001
volatile unsigned int zeci, unit, ref, level;
void vol_send_data(void);
//   functie ce desparte valoarea volumului in zeci si unitati
//    value function that divides the volume into tens and units
void decode_niv (unsigned int vol)
   if(vol >= 79)
         vol = 79;
   zeci = vol/10; // cifra zecilor
   unit = vol%10; // cifra unitatilor
      vol_send_data();
//    function that allows data transmission chip
void vol_send_data()
   i2c_start();
   i2c_write(0x88);  // Adress chip
   i2c_write(0b11100000 + zeci); //Write tens value
   i2c_write(0b11010000 + unit); //Write units value
   i2c_stop();
// The first function called in the program
void volume ()
   if(0x14 == ref)      // ref is reference value for comparation tast
         if(level <= 79)   // Maxim level is -79dB
         level++;
   if(0x13 == ref)
      {   if(level >= 1)
         level--;
   decode_niv(level);
// mute functions
void muting ()
   if(0x15 == ref)
         i2c_start();
   i2c_write(0b0111110001); //Write muting value
   i2c_stop();
all the best
Arsenic
PostPosted: Mon Nov 20, 2017 10:28 pm     Reply with quote
I don't understand the datasheet. How you raise/decrease the volume?
