PIC12F683 in SLEEP Mode
filjoa
PostPosted: Tue Jul 27, 2010 5:08 pm     Reply with quote
hi
I try put this PIC in sleep mode but it don't go.... or I think it...
#include <12F683.h>
#FUSES NOWDT, INTRC_IO, NOCPD, NOPROTECT, MCLR, PUT, NOBROWNOUT, NOIESO, NOFCMEN
#use delay(clock=8000000)
#define RAND_MAX 6
#include <STDLIB.H>
output_high(PIN_A5);
delay_ms(2000);
sleep();
PS: for example in this program after I call SLEEP() function PIN_A5 don't turnoff?
Someone can help me?
best regards
PostPosted: Tue Jul 27, 2010 6:05 pm     Reply with quote
For example in this program after I call SLEEP() function PIN_A5 don't turnoff?
Download the 12F683 and read the section on Sleep:
12.7 Power-Down Mode (Sleep)
It describes what the i/o pins do in Sleep mode. Read it.
filjoa
PostPosted: Wed Jul 28, 2010 7:52 pm     Reply with quote
Hi
For I make an rand sequence I make some like this:
#include <12F683.h>
#FUSES NOWDT, INTRC_IO, NOCPD, NOPROTECT, NOMCLR, PUT, NOBROWNOUT, NOIESO, NOFCMEN
while(input(PIN_A3)==1);
do {
   if (n==7) n=0;
   n=n+1;
   if (input(PIN_A3) == 1) aux=1;
   } while ((aux != 1));
switch (n)
   case 1 : output_a(0x01);
   case 2 : output_a(0x02);
   case 3 : output_a(0x03);
   case 4 : output_a(0x06);
   case 5 : output_a(0x07);
   case 6 : output_a(0x16);
delay_ms(10000);
output_a(0x00);
output_low(PIN_A5);
SLEEP();
But my PIN_A3 is MCLR but on fuse I use NOMCLR.
My problem now is, how I can return from SLEEP mode? is possible use reset switch? (attention on fuses because there I have NOMCLR).
best regards
filjoa
PostPosted: Thu Jul 29, 2010 5:51 am     Reply with quote
don't have other way to return from SLEEP MODE if I have MCLR desactivated?
best regards
FvM
PostPosted: Thu Jul 29, 2010 6:55 am     Reply with quote
Your motivation for using sleep mode is completely unclear. In my view, sleep mode makes only sense together with any event that wakes up, in most cases either a watchdog timeout or an external interrupt. But you don't enable a possible wake up event in your code. So a reset would be the only way to restart (not to wake up) the processor. I don't see what it's good for.
filjoa
PostPosted: Thu Jul 29, 2010 12:18 pm     Reply with quote
Hi
My idea is to save energy.
Can I use PIN_A3 to wake the PIC?
Clicking on PIN_A3 is an event I am doing right?
Best regards
FvM
PostPosted: Thu Jul 29, 2010 2:10 pm     Reply with quote
Yes, you have to enable the GPIO change interrupt for the respective pin.
filjoa
PostPosted: Thu Jul 29, 2010 4:58 pm     Reply with quote
Hi
How I can make this?
You can give an example?
I try this but give an error on compile.
#include <12F683.h>
[b]#int_ext
void int_ra3()
reset_cpu();
}[/b]
int8 i,aux=0,n=0;
int16 time;
   [b]enable_interrupts(GLOBAL);
   ext_int_edge(H_TO_L);
   enable_interrupts(INT_EXT);[/b]
do {
   if (n==7) n=0;
   n=n+1;
switch (n)
delay_ms(10000);
output_a(0x00);
output_low(PIN_A5);
SLEEP();
//while(input(PIN_A3)==1);
//reset_cpu();
best regards
filjoa
PostPosted: Thu Jul 29, 2010 5:52 pm     Reply with quote
hi
Thanks all
Problem is now solve...
#int_ra
void int_isr(void)
int8 i,aux=0,n=0;
int16 time;
disable_interrupts(INT_RA3);
enable_interrupts(INT_RA3);
SLEEP();
This syntax stay correct on sleep mode use?
best regards
