Making USB And Serial Work Together [solved]
kiewic
PostPosted: Sun May 16, 2010 11:03 am     Reply with quote
Hello. I have a PIC 18F2550 running with a 20MHz crystal and the following configuration.
#include <18F2550.h>
#device adc=8
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HSPLL                    //Internal RC Osc INTRC
#FUSES BROWNOUT               //No brownout reset NOBROWNOUT
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES PUT                    //No Power Up Timer NOPUT
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES MCLR                     //Master Clear pin enabled
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode) NOXINST
#FUSES PLL5                    //Divide By 12(48MHz oscillator input) PLL12
#FUSES CPUDIV1                  //System Clock by 4 CPUDIV4
#FUSES USBDIV                   //USB clock source comes from PLL divide by 2
#FUSES VREGEN                   //USB voltage regulator enabled
#use delay(clock=48000000)
Now, I need to read information from a serial RFID reader. It works at 2400 bps.
I have the following configuration for the serial communication, but it is reading garbage.
#use rs232(baud=2400, rcv=PIN_A0, ENABLE=PIN_A1, stream=RFID, PARITY=N, bits=8)
I have also tried with other baud values, like 12000, 480, 4800, 1200, 6000 and 960. But nothing works.
PostPosted: Sun May 16, 2010 11:48 am     Reply with quote
Post a link to the complete data sheet for the RFID reader.
kiewic
Oops!
PostPosted: Sun May 16, 2010 7:24 pm     Reply with quote
Hey, thanks for your interest. It was a power problem.
