darkeagle
| vsprintf: available in ccs? |
Posted: Fri May 07, 2010 7:10 am |
As the object, is the vsprintf available in ccs compiler?
d |
pippo1234
Posted: Fri May 07, 2010 4:03 pm |
Tested the sprintf with variable parameters but it does not work.
I think is necessary to write a vsprinft from scratch.
Anyone know a workaround?
P |
bkamen
Joined: 07 Jan 2004 Posts: 1619 Location: Central Illinois, USA
Posted: Fri May 07, 2010 5:46 pm |
There's a typo in the sample at that link, but I got it to compile..
Just didn't run it.
allenhuffman
Joined: 17 Jun 2019 Posts: 681 Location: Des Moines, Iowa, USA
Posted: Tue Oct 20, 2026 8:38 am |
I ran into a use for this today, and ended up here. Can confirm no vargs support in sprintf.
I have a bunch of places where I populate a buffer that will be returned in a "get debug data" message, and was hoping to make them more clever.
| Code: | // Log what happened.
char buffer[80];
sprintf (buffer, "%d current %f > %u",
index, current, currentLimit);
populateDebugDataBuffer (buffer, sizeof(buffer));
Ah well... what's a few more bytes between friends. _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Embedded C, Arduino, MSP430, ESP8266/32, and PIC24 programmer.
Using: 24FJ256GA106, 24EP256GP202, 24FJ64GA002 and 24FJ1024GA606. |
Posted: Tue Oct 20, 2026 12:05 pm |
CCS does support variable argument lists, but the problem with printf,
is that it doesn't have support built in for the format string to handle this.
So extend the number of arguments, and the argument string runs out,
and the code doesn't work.
If you are using a constant format for each item, you can make it work
by having your own function accepting the variable argument list, and
having this pass the arguments one by one to a standard printf, with a
single format string. This does work. You can generate this as a macro
and your own function, to make it behave like vsprintf. |
allenhuffman
Posted: Tue Oct 20, 2026 2:47 pm |
| Ttelmah wrote: | CCS does support variable argument lists, but the problem with printf,
Yeah, a robot suggested using a macro. Seems like a good approach. This was for logging arbitrary debug strings that could have just text, or any number of variables printed in them. I was just trying to prevent having that buffer and sprintf() each time. ;-) _________________ Allen C. Huffman, Sub-Etha Software (est. 1990) http://www.subethasoftware.com
Posted: Thu Oct 22, 2026 12:28 am |
Yes.
The reason this is 'difficult' in CCS, comes down to how the format strings
are handled. On most processors, the format handling is a program in
ROM, that scans the format string and parses this to handle the output.
In CCS, historically the compiler parses the format string at compile time
and then generates the code to handle each format. This saved RAM
massively, and on the original PIC's was really the only practical way of
doing this, It is perhaps sad that CCS haven't offered the traditional scan
behaviour as an option on the later PIC's. Certainly on the larger PIC18's
and even more on the PIC24/30/33, it'd really be the better way to go. |
