Problem presetting data into data EEPROM
TCC
PostPosted: Fri Apr 23, 2010 3:20 am     Reply with quote
I need to preset some data into data EEPROM and from CCS Help manual, there is something like #rom 0x2100={01,02,03,04,05,06,07}.
I tried it in my program, it couldn't work. Anyone can help?
I am currently using PIC16F1827, compiled with MPLAB PCM V4.106
FvM
PostPosted: Fri Apr 23, 2010 4:21 am     Reply with quote
"something like" isn't wrong but not particularly correct for this device.. Address 0x2100 is in the middle of the device's
program flash and actually couldn't work. Microchip has programming specifications for each device. Unfortunately,
the respective document doesn't tell about EEPROM address mapping. I guess, it's 0x8100.
hmmpic
PostPosted: Fri Apr 23, 2010 7:44 am     Reply with quote
For my 18F14K it's #ROM int8 0xF00000={0x01}
PostPosted: Fri Apr 23, 2010 11:33 am     Reply with quote
The data eeprom address is given in the 16F1827 Programming
Specification, which can be downloaded on this page:
http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en538963
See this section:
7.3 Data EEPROM
The physical address range of the 256 byte data
memory is 0000h-00FFh. However, these addresses
are logically mapped to address 1E000h-1E1FFh in the
hex file. This provides a way of differentiating between
the data and program memory locations in this range.
The format for data memory storage is one data byte
per address location, LSb aligned.
To get the physical address in the PIC, divide the Hex file address by 2.
This means the data eeprom starts at 0xF000.
You can verify this in the MPLAB simulator by compiling the test program
shown below. Then go to the View menu, and then to EEPROM, and you'll
see it's right there: 01 02 03 04 05
#include <16F1827.h>
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
#rom 0xF000 = {1,2,3,4,5}
pha555
PostPosted: Sat Apr 24, 2010 3:49 pm     Reply with quote
Thanks very much PCM programmer.
I spent a good deal of time and solved my problem when I found your post.
Cheers.
Peter Anderson
andrewg
PostPosted: Sat Apr 24, 2010 10:57 pm     Reply with quote
The following works too (in my 4.095, anyway):
#rom getenv("EEPROM_ADDRESS")={
Andrew
