SWITCH, CASE and BREAK
jjude
PostPosted: Fri Feb 12, 2010 4:07 am     Reply with quote
switch(xxx)
   case : 1
       if(input(PIN_A1)) break;
       else yyy = 0;
   break;  //COMING BREAK THIS
   default :
       if(input(PIN_B1)) break;
       else yyy = 1;
       break;  //OR THIS ???
Wayne_
PostPosted: Fri Feb 12, 2010 4:28 am     Reply with quote
Firstly, what is your question ?
Secondly you have an error.
case : 1 should be case 1:
note the colon is in the wrong place.
And lastly
switch(xxx)
   case 1:
// not required   {
       if(input(PIN_A1))
       yyy = 0;  // Could be done like this
// not required   }
   default :
// not required   {
       if(input(PIN_B1))
       else yyy = 1;
       // break;  NOT REQUIRED
// not required   }
Would look something like this
switch(xxx)
   case 1:
        if(!input(PIN_A1))
            yyy = 0;
   default :
       if(!input(PIN_B1))
           yyy = 1;
PostPosted: Fri Feb 12, 2010 4:53 am     Reply with quote
Much tidier. Smile
It is also worth being aware of a 'limitation' of the CCS implementation.
If you have a 'default' statement, though good in programming practice terms, this forces the switch statements to be individually tested. If instead all states are implemented with no 'default', the compiler uses a jump table. So, for the 'example' of dealing with cases from 1 to 10:
if (y<1 || y>10) {
    //Default operation outside the 'test' range
else switch (y) {
   case 1:
   case 2:
       //Code for these cases
   case 3:
   case 4:
   case 5:
   case 6:
   case 7:
   case 8:
   case 9:
       //Code for this case
   case 10:
       //Code for last case
By not having a 'default', and instead trapping this oneself, the compiler wll generate a jump table for all the used cases, giving equal execution time for all the cases. Slower for only a couple of cases (the compiler when I last tested it, would still perform individual tests for less than four cases), but for larger examples, much quicker.
Then, the original example given, can equally well be coded as:
if (xxx==1) {
        if(!input(PIN_A1))
            yyy = 0;
else {
       if(!input(PIN_B1))
           yyy = 1;
Though cases are a very tidy way of coding large numbers of choices, for a single value, use the if....
Petar_2010
Problem with switch
PostPosted: Thu Nov 22, 2018 3:56 am     Reply with quote
I have a problem with my code with the switch sentence.
The code is compiled correctly but the micro doesn´t work.
I want to have a different modules with steady light or intermittent depending of the state of the buttons.
I can´t see where is my error.
I apologize for my bad english.
This is my code:
// LEDS CONTROL
// 29/10/2018
#include <16F1828.h>
#fuses NOMCLR
#use delay(internal=8MHz)
#use FIXED_IO( A_outputs=PIN_A0,PIN_A1,PIN_A2,PIN_A3,PIN_A4,PIN_A5 )
#use FIXED_IO( B_outputs=PIN_B4,PIN_B5,PIN_B6,PIN_B7 )
#use STANDARD_IO(C)
// DEFINE INPUT BUTTONS
#define BUTTON_1 PIN_C0
#define BUTTON_2 PIN_C1
#define BUTTON_3 PIN_C2
#define BUTTON_4 PIN_C3
#define BUTTON_5 PIN_C4
// DEFINE OUTPUT LEDS
#define LED_GREEN PIN_A0
#define LED_AMBER PIN_A1
#define LED_RED PIN_A2
#define LED_WHITE PIN_A4
#define LED_BLUE PIN_A5
#use rs232(baud=9600,bits=8, parity=N,xmit=PIN_b5,rcv=PIN_b4)
// DEFINE FUNCTIONS
void steady_1();
void steady_2();
void steady_3();
void steady_4();
void steady_5();
void interm_1();
void interm_2();
void interm_3();
void interm_4();
void interm_5();
port_c_pullups(0xff);
int8 estados;
output_a(0x00);
while(true)
switch (estados)
case 1:
if(input(BUTTON_1)==0)
steady_1();
interm_1();
case 2:
if(input(BUTTON_2)==0)
steady_2();
interm_2();
case 3:
if(input(BUTTON_3)==0)
steady_3();
interm_3();
case 4:
if(input(BUTTON_4)==0)
steady_4();
interm_4();
case 5:
if(input(BUTTON_5)==0)
steady_5();
interm_5();
default:
output_a(0x00);
} //switch
} //while principal
} //main
//FUNCTIONS
void steady_1()
output_high(LED_GREEN);
void steady_2()
output_high(LED_AMBER);
void steady_3()
output_high(LED_RED);
void steady_4()
output_high(LED_WHITE);
void steady_5()
output_high(LED_BLUE);
void interm_1()
output_low(LED_GREEN);
void interm_2()
output_low(LED_AMBER);
void interm_3()
output_low(LED_RED);
void interm_4()
output_low(LED_WHITE);
void interm_5()
output_low(LED_BLUE);
PostPosted: Thu Nov 22, 2018 4:35 am     Reply with quote
1) Learn to use the code buttons.
2)
int8 estados;  //at this point estados is uninitialised
//could contain anything....
output_a(0x00);
while(true)
//What is going to set 'estados' to anything?. It starts with
//a value that probably does not correspond to any of your switch
//values, and nothing changes it....
//How is anything meant to happen?.
switch (estados)
Petar_2010
PostPosted: Sat Nov 24, 2018 11:52 am     Reply with quote
2)
output_a(0x00);
while(true)
switch (estados)
Thank you for your attention.
I think that I must to change the way.
I need three states: led ON steady, led ON intermittent and led OFF.
Every time pressing the push button I need to change different state.
Do you have any ideas?
PostPosted: Sat Nov 24, 2018 2:40 pm     Reply with quote
Yes, just initilise the variable to the default state value, and when you see your button, increment is (and when it reaches '3' set it back to zero.
You show the code using five buttons, now you are only using one?.
Remember also that detecting a button, requires you to look for it changing, not just the act of it being on, and you need to cope with the probability that there will be bounce (a button won't cleanly go 'on').
Petar_2010
PostPosted: Sun Nov 25, 2018 9:49 am     Reply with quote
Thank you for your time Ttelmah,
Yes I need work with five buttons, but I think that is easier work with only one at first and then with five.
I found in that forum a very good example of use of two states of push button - (state up - button released) and (state down - button pressed).
Now I have two states of every of the five buttons, but I need a third state - intermittent.
This is the code:
// LEDS CONTROL
// 29/10/2018
#fuses NOMCLR
#use STANDARD_IO(C)
output_a(0x00);
while(true)
   if((input(BUTTON_1) == 0)) //
//GREEN
char count;
count = 0;
while(true)
         delay_ms(10);
         if((input(BUTTON_1) == 0)) //debounce - antireplique
     count++;
      count = 0;
   if(count == 1)
   delay_ms(10);
while(true)
   if (input(BUTTON_1))
         delay_ms(10);
         if (input(BUTTON_1)) //debounce - antireplique
      count++;
      count = 0;
   if(count == 1)
   delay_ms(10);
count = 0;
output_toggle(LED_GREEN);
   if((input(BUTTON_2) == 0)) //
//AMBER
char count2;
count2 = 0;
while(true)
              delay_ms(10);
         if (input(BUTTON_2)) //debounce - antireplique
      count2++;
      count2 = 0;
   if(count2 == 1)
   delay_ms(10);
count2 = 0;
while(true)
            delay_ms(10);
      count2++;
      count2 = 0;
   if(count2 == 1)
   delay_ms(10);
output_toggle(LED_AMBER);
   if((input(BUTTON_3) == 0)) //
//RED
char count3;
count3 = 0;
while(true)
              delay_ms(10);
         if (input(BUTTON_3)) //debounce - antireplique
      count3++;
      count3 = 0;
   if(count3 == 1)
   delay_ms(10);
count3 = 0;
while(true)
            delay_ms(10);
      count3++;
      count3 = 0;
   if(count3 == 1)
   delay_ms(10);
output_toggle(LED_RED);
   if((input(BUTTON_4) == 0)) //
//WHITE
char count4;
count4 = 0;
while(true)
              delay_ms(10);
         if (input(BUTTON_4)) //debounce - antireplique
      count4++;
      count4 = 0;
   if(count4 == 1)
   delay_ms(10);
count4 = 0;
while(true)
            delay_ms(10);
      count4++;
      count4 = 0;
   if(count4 == 1)
   delay_ms(10);
output_toggle(LED_WHITE);
   if((input(BUTTON_5) == 0)) //
//BLUE
char count5;
count5 = 0;
while(true)
              delay_ms(10);
         if (input(BUTTON_5)) //debounce - antireplique
      count5++;
      count5 = 0;
   if(count5 == 1)
   delay_ms(10);
count5 = 0;
while(true)
            delay_ms(10);
      count5++;
      count5 = 0;
   if(count5 == 1)
   delay_ms(10);
output_toggle(LED_BLUE);
   } //while principal
} //void main
PostPosted: Sun Nov 25, 2018 2:15 pm     Reply with quote
int16 buttons[]={PIN_C0, PIN_C1, PIN_C2, PIN_C3, PIN_C4};
int16 leds[]={PIN_A0, PIN_A1, PIN_A2, PIN_A3, PIN_A4};
enum state {OFF, FLASH, ON};
enum states[] = {OFF,OFF,OFF,OFF,OFF}; //initial states
int8 keys[]= {0,0,0,0,0};
#INT_TIMER2
void tick(void)
    //Tick needs to scan keys, and handle flash state
    int8 ctr;
    static int8 flashctr=0;
    flashctr++;
    for (ctr=0;ctr<5;ctr++) //five keys
        if (input(buttons[ctr])==0)
            keys[ctr]++; //increment counter if key pressed
            keys[ctr]==0; //clear if released
        if (keys[ctr>3)
            keys[ctr]==3; //prevent key repeating
        if (keys[ctr]==2) //after two ticks
            states[ctr]++; //increment state.
            if (states[ctr]>ON)
               states[ctr]=OFF; //wrap back to off
        switch states[ctr] {
        case OFF:  //LED off
            output_low(leds[ctr];
        case FLASH: //flash leds
            if (flashctr<10)
                output_high(leds[ctr]);
                output_low(leds[ctr]);
        case ON:
    if (flashctr>=20)
        flashctr=0;
    setup_timer2(T2_DIV_64, 249,  12); //just under 10Hz
    while(TRUE);
No guarantees, typed in and not checked. However shows how to be
handling all five keys and leds, with all working.
Petar_2010
PostPosted: Wed Nov 28, 2018 2:21 am     Reply with quote
Many, many thanks Ttelmah,
Very good job, but a little bit complicated. I need to learn more for can use your idea.
However, I´m very grateful.
PostPosted: Wed Nov 28, 2018 2:41 am     Reply with quote
Evil grin....
However it is actually very simple.
A master 'tick'. Happens at about 10Hz.
This tests each button (using an array of button numbers). If the button is 'on'
increments a counter for that button. If off, clears the counter.
If the counter reaches '2', says 'on', and increments the operation state for that
button.
The state has three possibilities. OFF, FLASH, ON.
Then for each button, tests the state. If it is 'OFF' turns the LED off. If ON turns
the LED ON> IF it is in the 'FLASH' state, it turns it on if another counter being
run in the interrupt, is 10 to 20, or off if it is 0 to 9. So flashes the LED.
Now the events never delay, each test passes immediately to the next in
sequence, so the whole thing handles each button, and output in turn.
Problem with your existing code, is it only does one thing after another, and
so while it is flashing LED2 (say), it is not able to check any of the other
keys or flash any other LED.
