| 18F8722 Half Bridge PWM doesn't work? |
Posted: Wed Feb 03, 2010 8:03 pm |
Hi Folks,
Trying to get a half bridge PWM working using the 18F8722 ECCP module. One of the outputs (P1A on C2) seems to work just great, but I can't seem to get anything out of the other one (P1B on H7). See my code below.
Thanks!
Greg
Header File:
#include <18F8722.h>
#device adc=8
#FUSES BORV25 //Brownout reset at 2.5V
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES MCU //Microcontroller Mode
#FUSES NOWAIT //Wait selections unavailable for Table Reads or Table Writes
#FUSES BW16 //16-bit external bus mode
#FUSES ABW20 //20-bit Address bus
#FUSES ECCPE //Enhanced CCP PWM outpts multiplexed with RE6 thorugh RE3
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,errors)
#use i2c(Slave,Fast,sda=PIN_C4,scl=PIN_C3,address=0xA0)
#define PR2 0xFCB
#define CCPR1L 0xFBE
#define ECCP1DEL 0xF79
#define CONFIG3H 0x300005
#define TRISC 0xF94
#define TRISD 0xF95
#define TRISH 0xF99
#define CCP1CON 0xFBD
#define ECCP1 CCP1CON
#define ECCP1AS 0xFB6
#define RED_LED PIN_B5
#define YELLOW_LED PIN_B4
#define GREEN_LED PIN_A5
void Initialize(void);
#include "C:\Documents and Settings\Administrator\Desktop\GBCWMII EE4040-PWM\OutputStage.h"
#include <stdlib.h>
void main() {
Initialize();
// TODO: USER CODE!!
while(1) {
//output_high(PIN_H7);
output_high(GREEN_LED);
//output_low(PIN_H7);
output_low(GREEN_LED);
output_high(YELLOW_LED);
output_low(YELLOW_LED);
output_high(RED_LED);
output_low(RED_LED);
void Initialize(void) {
*TRISC = 0x00; //Set Port C to outputs.
*TRISD = 0x00; //Set Port D to outputs.
*TRISH = 0x00; //Set Port H to outputs.
setup_psp(PSP_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_1,0,1);//(mode,period,postscale);
setup_vref(FALSE);
setup_low_volt_detect(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
SETUP_CCP1(CCP_PWM|CCP_PWM_HALF_BRIDGE|CCP_PWM_H_H);
//CP1CON = 0x8c;
*CONFIG3H = 0x81; //Multiplexes P1B from RE6 onto RH7
*PR2 = 24; //Period = 4 * Tosc *(PR2+1) * TMR2Prescaler
*CCPR1L = 0x0c; //Duty Cycle = Tosc * (CCPR1L<7:0>:CCP1CON<5:4>) * TMR2Prescaler -- for ease of use, ignore LSBs.
*ECCP1DEL = 0x03|0x80; //Delay = 4 * Tosc * (ECCP1DEL<6:0>)
*ECCP1AS = 0x00; //ECCP outputs are operating
Posted: Wed Feb 03, 2010 8:18 pm |
| Post your compiler version. |
Posted: Wed Feb 03, 2010 8:48 pm |
Hi sorry, it turns out that once I had the fuse set like this #FUSES ECCPE, the PWM output could not be changed in software:
Changing the fuse to #FUSES ECCPH fixed the problem entirely. Sorry for the bother.
Cheers,
Greg |
