How I can write a string into a ram and then read that?
pilar
PostPosted: Wed Dec 09, 2009 10:34 am     Reply with quote
Hi, I am using a pic18f452 to read the data GPS and then save these data in the internal EEPROM pic together with others data (analogic inputs) and then send to PC by serial port. This is done every 2 minutes. According to data sheet of pic18f452 only can be 1,000,000 erase/write cycle Data EEPROM. This is not true with memory RAM that have erase/write cycle infinite.
I think that after a long time the eeprom memory will become obsolete and have to change the pic.
I can write the GPS data an analogics input in the memory RAM and after read these to send the PC?
How I can do it?
dbotkin
PostPosted: Wed Dec 09, 2009 11:10 am     Reply with quote
Why not just define a serial buffer (or an array of them)?
char gpsdata[32];
gets(gpsdata);           // Read GPS data into RAM
printf("%s\n",gpsdata);  // Print to PC
bkamen
PostPosted: Wed Dec 09, 2009 11:58 am     Reply with quote
char gpsdata[32];
That's pretty simplified, but would work.
Warning - Some GPS strings are longer than 31chars and would overflow that buffer.
Cheers,
Ben
dbotkin
PostPosted: Wed Dec 09, 2009 1:09 pm     Reply with quote
Well, yeah... you'll need to make the string variable(s) as long as you need to store the data. Point is, it's dead simple to store the data in RAM until it's send to the PC. Easier, even, than storing it in EEPROM.
bkamen
PostPosted: Wed Dec 09, 2009 1:16 pm     Reply with quote
:D ok - we're on the same page then.
And yes, EEPROM != RAM. (to the original poster)
-Ben
