rkinchin Guest
WHAT THE..... Even RS232 doesnt work, does anything work!!! |
Posted: Wed Dec 09, 2009 12:02 pm |
Found so many bug in this compiler thought I would use a simple RS232
First for some stupid reason UART1 produces code for UART4 and attempting to use any other uart produces a compiler error
Anyone get this to work!!!
#include<24FJ256GB110.h>
#FUSES NOJTAG //JTAG disabled
#FUSES DEBUG //Debug mode for use with ICD
#FUSES ICSP1 //ICD uses PGC1/PGD1 pins
#FUSES WINDIS //Watch Dog Timer in non-Window mode
#FUSES WPRES128 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16 //Watch Dog Timer PostScalar 1:32768
#FUSES PR_PLL //Primary Oscillator with PLL
#FUSES NOCKSFSM //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES OSCIO //OSC2 is general purpose output
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES NOIOL1WAY //Allows multiple reconfigurations of peripheral pins
#FUSES WPEND_LOW
#FUSES WPCFG
#FUSES WPDIS
#FUSES WPFP0
#FUSES PLL1 //Divide By 1(4MHz oscillator input)
#FUSES RESERVED //Used to set the reserved FUSE bits
#FUSES DISUVREG
#use delay(clock=48M,RESTART_WDT,cyrstal=4M)
#use rs232(uart2,baud=9600)
#pin_select U2TX=PIN_B8
main()
This was compiled using 4.101 and got
Executing: "C:\Program files\Picc\CCSC.exe" +FD "xxx.c" +DF +LN -T +A +M -Z +Y=9 +EA
*** Error 100 "xxx.C" Line 27(5,28): USE parameter value is out of range No Second UART
1 Errors, 0 Warnings.
Halting build on first failure as requested.
BUILD FAILED: Wed Dec 09 17:42:33 2009
[/code]
Oh and the baud rate 9600 produces a bit rate of 160uS
So NUFFIN WORKS |
Posted: Wed Dec 09, 2009 12:47 pm |
Switch to 18F PICs. You'll be happier.
This remark is not intended to be mean. The PCD compiler is irritating
to you. The PCH compiler will be a lot less irritating, and you'll be
happier. |
Posted: Wed Dec 09, 2009 2:48 pm |
No the compiler is not irritating me, I am a professional and I need to have tools that work, My projects requires PIC24 and 18's are not powerful enough for the tasks, I expected better from PCD. These are very basic functions of the compiler and not finger trouble, I have been using the PCH for years now so I am used to CCS ways. |
