		| Author | Message |
		| pyu
				| Error: Previous identifier must be a pointer |
				|  Posted: Thu Oct 08, 2009 1:54 pm |   |
				| Hi.
 I have declared
  	  | Code: |  	  | signed int16 Temp[4]; |
 Then,
  	  | Code: |  	  | for (numRoms=1;numRoms<=4;numRoms++) {
 if (Send_MatchRom())
 write_byte(0xBE); // Read scratch pad command
 dowcrc = 0;       // Reset the crc to start a new calculation
 for (i=0;i<=7;i++)
 scratch[i] = read_byte();
 ow_crc(scratch[i]);     // Accumulate the crc
 scratch[8] = read_byte();   // Received crc byte
 ow_reset();
 // If calculated crc from incoming bytes equal to crc byte
 // then data is valid. Calculate and output temperature.
 if (scratch[8] == dowcrc)
 temp = make16(scratch[1],scratch[0]);
 result = (float) temp / 16.0; //0.1 deg C resolution
 //printf(lcd_putc,"\fT%i= %3.1f \uC", numRoms, result);
 Temp[numRoms] = result;
 printf(lcd_putc,"\fData error.");       // There was an error in the data
 I want to assign a value to Temp[0], Temp[1], Temp[2], Temp[3],
 and then to print this value to LCD.
  	  | Code: |  	  | printf(lcd_putc, "\nENG:\%3.1fC \EXT:%2.1fC", Temp[0], Temp[1]); |
 I get 2 errors:
  	  | Quote: |  	  | ** Error 116 "C:\Car_LCD\CarLCD.c" Line 570(62,63): Printf variable count (%) does not match actual count  :: *** Error 66 "C:\Car_LCD\CarLCD.c" Line 638(6,13): Previous identifier must be a pointer
 First error I get it from this line:
 The second error:
  	  | Code: |  	  | Temp[numRoms] = result; |
 What is wrong in my code?
		| PCM programmer
				|  Posted: Thu Oct 08, 2009 2:14 pm |   |
				|  	  | Quote: |  	  | signed int16 Temp[4]; printf(lcd_putc, "\nENG:\%3.1fC \EXT:%2.1fC", Temp[0], Temp[1]);
 Look at your code.  You have an array of 'signed int' values, but you're
 trying to display them as floating point numbers.
  	  | Quote: |  	  | Temp[numRoms] = result; |
 You didn't post the declarations for 'numRoms' or 'result'.
 It's easier to give you an answer if you post a real test program,
 with all varible declarations, and that is compilable.   Also post
 your PIC and compiler version.
		| Wayne_
				|  Posted: Fri Oct 09, 2009 1:59 am |   |
				| Surely the problem lies with the fact the '\' is an escape char i.e
 \% will escape the %
 If your intention is to disply a '\' then you need to use 2 off them but I suspect you have just made a mistake! :-
 printf(lcd_putc, "\nENG: %3.1fC EXT:%2.1fC", Temp[0], Temp[1]);
 But PCM programmer has a valid point.
		| pyu
		| Wayne_
				|  Posted: Fri Oct 09, 2009 2:44 am |   |
				| An array has a zero based index in C
 So
 gives you
 Temp[0] to Temp[3]
 you either need to change your for loop
 for (numRoms=0;numRoms<=3;numRoms++)
 or change the assignment.
 Temp[numRoms - 1] = result;
 I don't think this is your problem though.
 post more info, including definitions of vars used.
		| pyu
				|  Posted: Fri Oct 09, 2009 2:53 am |   |
				|  	  | Wayne_ wrote: |  	  | An array has a zero based index in C or change the assignment.
 I tried
 , but no succes. 	  | Code: |  	  | Temp[numROMs - 1] = result; |
 In previous post, I added a zip with my project.
 Here is a sample code:
  	  | Code: |  	  | int8 numROMs;
 float Temp[4];
 void Read_DS_Temperature(void)
 int8 i;
 signed int16 temperature;
 int8 scratch[9];
 signed int16 temp;
 float result=0;
 if (!ow_reset())     // If a device is present
 write_byte(0xCC); // Skip Rom command
 write_byte(0x44); // Temperature convert command
 output_float(DQ);
 delay_ms(750);    // Max. conv. time is 750mS for 12 bit
 ow_reset();
 // Now get the device raw temperature data using Match ROM with the
 // addresses obtained with FindDevices().  Scale to deg. C, scaling is
 // 0.0625 (1/16) deg. C/bit with default 12 bit res. Could reduce res.
 // and therefore shorten conversion time if necessary.
 // Output the temperatures in whole degrees, apply rounding by adding
 // half denom.
 for (numROMs=1;numROMs<=4;numROMs++)
 for (i=0;i<=7;i++)
 ow_reset();
 printf(lcd_putc,"\fSenzor Error!");
 then:
 while(1){
		| Wayne_
				|  Posted: Fri Oct 09, 2009 3:33 am |   |
				| So which error are you still getting and what is the line ? please show code surrounding this and any definitions as well. |  |
		| pyu
				|  Posted: Fri Oct 09, 2009 3:41 am |   |
				| Error:  	  | Code: |  	  | *** Error 66 "C:\Car_LCD\CarLCD.c" Line 638(6,13): Previous identifier must be a pointer |
 Line:
 main.c:
  	  | Code: |  	  | #include <16F887.H>
 #include <math.h>
 #fuses HS,NOWDT,NOLVP,PUT,NOPROTECT,NOBROWNOUT,NOWRT
 #use delay(clock = 20000000)
 //#device adc=10  *=16      - ???
 #define DQ PIN_E0 // One Wire Bus pin assignment
 #define RTC_SDA  PIN_C4
 #define RTC_SCL  PIN_C3
 #use I2C(MULTI_MASTER,sda=RTC_SDA, scl=RTC_SCL)
 #include "Flex_LCD420.c"
 #include "CarLCD.h"
 #include "CarLCD.c"
 output_float(DQ);       // Set as input. 4k7 pullup on bus.
 FindDevices();
 ow_reset();
 DisplayInformations();
 CarLCD.h:
  	  | Code: |  	  | // Global variables
 int8 Rom_Bit[8]; // Rom_Bit bit
 int8 lastDiscrep = 0;
 short doneFlag = 0;
 int8 FoundROM[7][8]; // Table of found ROM codes, 8 bytes for each
 int8 numROMs;
 int8 dowcrc; // crc is accumulated in this variable
 // crc lookup table
 int8 const dscrc_table[] = {
 0,94,188,226,97,63,221,131,194,156,126,32,163,253,31,65,
 157,195,33,127,252,162,64,30,95,1,227,189,62,96,130,220,
 35,125,159,193,66,28,254,160,225,191,93,3,128,222,60,98,
 190,224,2,92,223,129,99,61,124,34,192,158,29,67,161,255,
 70,24,250,164,39,121,155,197,132,218,56,102,229,187,89,7,
 219,133,103,57,186,228,6,88,25,71,165,251,120,38,196,154,
 101,59,217,135,4,90,184,230,167,249,27,69,198,152,122,36,
 248,166,68,26,153,199,37,123,58,100,134,216,91,5,231,185,
 140,210,48,110,237,179,81,15,78,16,242,172,47,113,147,205,
 17,79,173,243,112,46,204,146,211,141,111,49,178,236,14,80,
 175,241,19,77,206,144,114,44,109,51,209,143,12,82,176,238,
 50,108,142,208,83,13,239,177,240,174,76,18,145,207,45,115,
 202,148,118,40,171,245,23,73,8,86,180,234,105,55,213,139,
 87,9,235,181,54,104,138,212,149,203,41,119,244,170,72,22,
 233,183,85,11,136,214,52,106,43,117,151,201,74,20,246,168,
 116,42,200,150,21,75,169,247,182,232,10,84,215,137,107,53
 // Returns 0 for one wire device presence, 1 for none
 int8 ow_reset(void);
 // Read bit on one wire bus
 int8 read_bit(void);
 void write_bit(int8 bitval) ;
 int8 read_byte(void) ;
 void write_byte(int8 val) ;
 // One wire crc
 int8 ow_crc(int8 x) ;
 // Searches for the next device on the one wire bus. If there are no more
 // devices on the bus then false is returned.
 int8 Next(void);
 // Resets current state of a ROM search and calls Next to find the first device
 // on the one wire bus.
 int8 First(void);
 void FindDevices(void);
 // Sends Match ROM command to bus then device address
 int8 Send_MatchRom(void);
 float Temp[4];
 CarLCD.c:
  	  | Code: |  	  | //DS18B20
 int8 ow_reset(void)
 int8 presence;
 output_low(DQ);
 delay_us(488);          // Min. 480uS
 output_float(DQ);
 delay_us(72);           // Takes 15 to 60uS for devices to respond
 presence = input(DQ);
 delay_us(424);          // Wait for end of timeslot
 //printf(lcd_putc, "\fPresence= %i", presence);
 //delay_ms(500);
 return(presence);
 int8 read_bit(void)
 output_low(DQ);
 delay_us(1);         // 1uS min. Original code relied on 8051 being slow
 output_float(DQ);
 delay_us(20);        // Wait at least 15mS from start of time slot
 return(input(DQ));   // Delay to finish time slot (total 60 to 120uS)
 } // must be done next.
 output_low(DQ);
 if(bitval == 1) {
 output_float(DQ);
 delay_us(105);       // Wait for end of timeslot
 output_float(DQ);
 int8 i;
 int8 val = 0;
 for(i=0;i<8;i++)
 if(read_bit()) val |= (0x01 << i);
 delay_us(120);  // To finish time slot
 return val;
 int8 i;
 int8 temp;
 for (i=0;i<8;i++)
 temp = val >> i;
 temp &= 0x01;
 write_bit(temp);
 delay_us(105);
 // One wire crc
 int8 ow_crc(int8 x)
 dowcrc = dscrc_table[dowcrc^x];
 return dowcrc;
 int8 Next(void)
 int8 m = 1;             // ROM Bit index
 int8 n = 0;             // ROM Byte index
 int8 k = 1;             // Bit mask
 int8 x = 0;
 int8 discrepMarker = 0;
 int8 g;                 // Output bit
 int8 nxt;               // Return value
 short flag;
 nxt = FALSE;            // Reset next flag to false
 dowcrc = 0;             // Reset the dowcrc
 flag = ow_reset();
 if (flag||doneFlag)     // If no parts return false
 lastDiscrep = 0;     // Reset the search
 return FALSE;
 write_byte(0xF0);       // Send SearchROM command
 do
 x = 0;
 if (read_bit() == 1)
 x = 2;
 delay_us(120);
 x |= 1;   // And it's complement
 if (x == 3)                   // There are no devices on the one wire bus
 if (x > 0)                 // All devices coupled have 0 or 1
 g = x >> 1;             // Bit write value for search
 // If this discrepancy is before the last discrepancy on a previous
 // Next then pick the same as last time.
 if (m < lastDiscrep)
 g = ((Rom_Bit[n] & k) > 0);
 // If equal to last pick 1
 g = (m == lastDiscrep);  // If not then pick 0
 // If 0 was picked then record position with mask k
 if (g == 0) discrepMarker = m;
 // Isolate bit in Rom_Bit[n] with mask k
 if (g == 1)
 Rom_Bit[n] |= k;
 Rom_Bit[n] &= ~k;
 write_bit(g);  // ROM search write
 m++;           // Increment bit counter m
 k = k << 1;    // and shift the bit mask k
 // If the mask is 0 then go to new ROM
 if (k == 0)
 {  // Byte n and reset mask
 ow_crc(Rom_Bit[n]);      // Accumulate the crc
 n++;
 k++;
 } while (n < 8);  // Loop through until through all ROM bytes 0-7
 if (m < (65||dowcrc))   // If search was unsuccessful then
 lastDiscrep = 0;     // reset the last Discrepancy to zero
 else  // Search was successful, so set lastDiscrep, lastOne, nxt
 lastDiscrep = discrepMarker;
 doneFlag = (lastDiscrep == 0);
 nxt = TRUE; // Indicates search not yet complete, more parts remain
 return nxt;
 int8 First(void)
 lastDiscrep = 0;
 doneFlag = FALSE;
 return Next(); // Call Next and return it's return value;
 int8 m;
 if(!ow_reset())
 if(First())    // Begins when at least one part found
 numROMs = 0;
 do
 numROMs++;
 for (m=0;m<8;m++)
 FoundROM[numROMs][m] = Rom_Bit[m];   // Identifies ROM no. on device
 //printf("Device No.%u address ",numROMs);
 //printf(lcd_putc,"%u  no dev=",numROMs);
 //delay_ms(1000);
 printf(lcd_putc, "\f%X%X%X%X%X%X%X%X",
 FoundROM[numROMs][7],FoundROM[numROMs][6],FoundROM[numROMs][5], \
 FoundROM[numROMs][4],FoundROM[numROMs][3],FoundROM[numROMs][2], \
 FoundROM[numROMs][1],FoundROM[numROMs][0]);
 //printf("%X%X%X%X%X%X%X%X\n\r",
 //FoundROM[numROMs][7],FoundROM[numROMs][6],FoundROM[numROMs][5],
 //FoundROM[numROMs][4],FoundROM[numROMs][3],FoundROM[numROMs][2],
 //FoundROM[numROMs][1],FoundROM[numROMs][0]);
 } while (Next() && (numROMs<10));   // Continues until no additional
 // devices found.
 printf(lcd_putc, "\fno ROM found");
 //delay_ms(500);
 printf(lcd_putc, "\fno ROM found2");
 //delay_ms(500);
 //putc('\n'); putc('\r');
 int8 i;
 if (ow_reset()) return FALSE;          // 0 if device present
 write_byte(0x55);                      // Match ROM
 for (i=0;i<8;i++)
 write_byte(FoundRom[numROMs][i]);   // Send ROM code
 return TRUE;
 void DisplayInformations(void)
 Read_DS_Temperature();
 int8 i;
 int8 scratch[9];
 signed int16 temp;
 float result=0;
 output_float(DQ);
 ow_reset();
 // half denom.
 for (i=0;i<=7;i++)
 ow_reset();
		| FvM
				|  Posted: Fri Oct 09, 2009 4:11 am |   |
				| It's a simple matter of code confusion.
 On one hand you're utilizing the default case insensitive behaviour of CCS C (you get many errors, when activating #case for you code), on the other hand you have this:
  	  | Code: |  	  | int16 temp; // and at another place
 float Temp[4];
 Decide, if you are going for #case or #nocase and correct your code respectively.
		| pyu
				|  Posted: Mon Oct 12, 2009 3:55 am |   |
				| Thanks FvM. It's working now!
 | You cannot post new topics in this forum You cannot reply to topics in this forum
