10 bit Analog CSV into buffer properly to write to SDCARD
gomond
PostPosted: Sat Sep 26, 2009 6:27 pm     Reply with quote
I am attempting to write AN0-->AN4 into a buffer and then out to an SD_CARD using f_write() (BE sd card library).
Is it possible to use fprintf() with the BE_SD library as I noticed that in the ELM version f_printf() is implimented.
This is what I have tried so far with mixed results and various methods.
//Analog functions
//char * anabuf;
unsigned long anabuf[12];
struct {
    unsigned long zero;
    unsigned long one;
    unsigned long two;
    unsigned long three;
    unsigned long four;
   }analoginput;
void Service_Analog_Inputs(void)
FIL fdst;           // file structures
FRESULT result;     // FatFs function common result code
WORD btw, bw;       // File R/W count
char mesg[64];
set_adc_channel(0);
delay_us(10);
//analoginput.zero = read_adc();
itoa(read_adc(),10,anabuf[0]);
set_adc_channel(1);
delay_us(10);
//analoginput.one = read_adc();
itoa(read_adc(),10,anabuf[2]);
set_adc_channel(2);
delay_us(10);
//analoginput.two = read_adc();
itoa(read_adc(),10,anabuf[4]);
set_adc_channel(3);
delay_us(10);
//analoginput.three = read_adc();
itoa(read_adc(),10,anabuf[6]);
set_adc_channel(4);
delay_us(10);
//analoginput.four = read_adc();
itoa(read_adc(),10,anabuf[8]);
anabuf[1]=",";anabuf[3]=",";anabuf[5]=",";anabuf[7]=",";anabuf[9]=",";
anabuf[10]="\r";anabuf[11]="\n";
//sprintf(anabuf,"%uL,%uL,%uL,%uL,%uL\r\n",analoginput.zero,analoginput.one,analoginput.two,analoginput.three,analoginput.four); // used with *anabuf
printf(anabuf);
   if (logging)
      btw = strlen(anabuf);
      result = f_write(&fdata, anabuf, btw, &bw);
      f_sync(&fdata);
      //printf("%s\n\r",anabuf);
      lcd_gotoxy(1,2);
      printf(lcd_putc,"%d\n",passes);
      passes ++;
      if (result)
         f_get_error_mesg(result,mesg);
         printf("Error writing to the data file\r\n");
         printf(lcd_putc,"\nFILE SYSTEM ERROR - %s",mesg);
         //return (result);
    else printf("Error dataloging not enabled\r\n");
   //return(FR_OK);
//  printf("Analog values are: 0=%Lu, 1=%Lu, 2=%Lu, 3=%Lu, 4=%Lu\n\r",\
//  analoginput.zero,analoginput.one,analoginput.two,analoginput.three,analoginput.four);
Its probably real simple to do correctly, but if I don't ask I will never know.
asmallri
PostPosted: Sat Sep 26, 2009 8:44 pm     Reply with quote
The driver does not implement f_printf directly. Here is one way you would do this using sprintf to build your formatted string and f_write to output it.
sprintf(mesg,"Analog values are: 0=%Lu, 1=%Lu, 2=%Lu, 3=%Lu, 4=%Lu\r\n",\
f_write(&fdata, (void*)mesg, strlen(mesg), &bw);
Regards, Andrew
gomond
PostPosted: Sat Sep 26, 2009 9:59 pm     Reply with quote
Thanks Andrew that worked, though at the start of the file there is a series of chars that pad the start for some obscure reason.
in HexEdit They are:
(0x0C 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00)
In wordpad:(blank line +11 spaces)
Blank Line
___________Analog values are: 0=1023, 1=5, 2=1, 3=5, 4=1020
//Analog functions
struct {
    unsigned long zero;
    unsigned long one;
    unsigned long two;
    unsigned long four;
   }analoginput;
BYTE Service_Analog_Inputs(void)
//FIL fdst;           // file structures
char mesg[64];
char anabuf[64];
set_adc_channel(0);
delay_us(10);
set_adc_channel(1);
delay_us(10);
set_adc_channel(2);
delay_us(10);
set_adc_channel(3);
delay_us(10);
set_adc_channel(4);
delay_us(10);
sprintf(anabuf,"Analog values are: 0=%Lu, 1=%Lu, 2=%Lu, 3=%Lu, 4=%Lu\r\n",\
//printf("DEBUG: %s",anabuf);
   if (logging)
      result = f_write(&fdata, (void*)anabuf, strlen(anabuf), &bw);
      f_sync(&fdata);
      lcd_gotoxy(1,2);
      printf(lcd_putc,"Samples: %d\n",passes);
      passes ++;
      if (result)
         return (result);
return(FR_OK);
Andrew how difficult is it to timestamp the start of each line using the Software RTC?
Greg O.
asmallri
PostPosted: Sat Sep 26, 2009 10:50 pm     Reply with quote
Try this.
use sprintf to build your string.
Once this is done use memcpy to copy the newly built string to another string (call it dummy).
Then use f_write operating on dummy.
Let me know how you get on with it.
Regards, Andrew
gomond
PostPosted: Sat Sep 26, 2009 11:27 pm     Reply with quote
Hi Andrew same result.
blank line (0c)
_11 NULLS_1023,1,4,2,21
1023,1,4,2,21
1023,1,4,1,21
1023,1,4,1,21
1023,1,4,2,21
1023,1,4,2,21
1023,1,4,1,21
1023,1,4,2,21
1023,1,4,1,21
1023,1,4,2,21
Snippets...
char anabuf[26];
char dummy[26];
sprintf(anabuf,"%Lu,%Lu,%Lu,%Lu,%Lu\r\n",\
memcpy(dummy,anabuf,26);
 result = f_write(&fdata, (void*)dummy, strlen(dummy), &bw);
      f_sync(&fdata);
asmallri
PostPosted: Sat Sep 26, 2009 11:40 pm     Reply with quote
Where ever you open the file, immediately after opening the file write a hello world string to the file.
Regards, Andrew
gomond
PostPosted: Sat Sep 26, 2009 11:54 pm     Reply with quote
I have copied the logging_start(), logging_stop() and OpenDataFile() functions over to the Sample FAT.c example.
and I am using logger_start(); to open the file and leaving it open until logger_stop();
I have emailed you the file as I dont know if you wanted of your IP posted.
Thanks again
Greg.
