Can-bus, 18F2580+MCP2551. Loopback ok, real can not working.
Goto page Previous  1, 2, 3
halibatsuiba
PostPosted: Sun Sep 27, 2009 10:10 pm     Reply with quote
halibatsuiba wrote:
Debugging continues... Cool
Whadda'y'know...
I could not think of anything else to try so I built another board #2 to a brand new breadboard and...
It works!
I can send characters from terminal over RS232 to board #1, board #1 sends them over CAN bus to board #2 who, in turn, echoes them back to terminal via board #1.
Shocked
[With voice of TV commercial]: "It works, It really works!"
Looks like there is two rows shorted in my old trusted currently-in-the-trashcan breadboard! Embarassed
Thank you, PCM, very much for your help in this issue.
ivrj
PostPosted: Wed Oct 14, 2009 4:29 pm     Reply with quote
I am also having the same problem.
My board #1 stops on:
while(!can_kbhit());
I've modified the source to be easy to debug:
#include <18F2580.h>
#fuses HS, NOPROTECT, PUT, BROWNOUT, NOWDT, NOLVP
#include <can-18F4580.c>  // Use correct driver
#define BOARD1_ID  24
#define BOARD2_ID  25
// Uncomment this line to compile code for Board #1.
// Comment it out to compile for Board #2.
//#define BOARD1   1
   struct rx_stat rxstat;
   int32 rx_id;
   int32 tx_id;
   int8 rx_len,i;
   int8 buffer[8];
   can_init();
   // starting
   for(i = 0; i < 13; i++)
            output_toggle(pin_a1);
            delay_ms(90);
            output_toggle(pin_a0);
            delay_ms(90);
   output_low(pin_a0);
   output_low(pin_a1);
   delay_ms(400);
   #ifdef BOARD1   // For Board #1
      printf("Press a key\r");
      output_high(pin_a0);
      buffer[0] = getc();   // Wait for a character
      printf("lido:%s ", buffer[0]);
      output_low(pin_a0);
      // Transmit it to board #2.
      if(can_putd(BOARD2_ID, buffer, 1, 1, 1, 0))
         printf("Sending a msg\r");
         for(i = 0; i < 6; i++)
         output_low(pin_a0);
         printf("Msg sending fail\r");
         for(i = 0; i < 15; i++)
             delay_ms(50);
             output_low(pin_a0);
      buffer[0] = 0;   // Clear the buffer byte
      // Wait for the char to be echoed back.
      if(can_getd(rx_id, buffer, rx_len, rxstat))
         printf("msg received\r");
         for(i = 0; i < 10; i++)
            delay_ms(50);
         output_low(pin_a1);
         if(rx_id == BOARD1_ID)  // Is it for this board ?
               delay_ms(50);
            output_low(pin_a1);
            printf("msg:" );
            putc(buffer[0]);  // If so, display the char
#else  // For Board #2
      if(can_kbhit())  // Message available ?
         for(i = 0; i < 6; i++)  // blink a received led
            output_low(pin_a0);
         // If so, get the message.
            if(rx_id == BOARD2_ID)  // Is it for this board ?
               for(i = 0; i < 14; i++)  // blink a received led
                  delay_ms(50);
               output_low(pin_a0);
               // If so, echo back the character.
               can_putd(BOARD1_ID, buffer, 1, 1, 1, 0);
I just changed the oscilator from 20mhz to 4mhz.
I still have some doubts on the circuit, can somebody post the real circuit schematic?
Just to show my circuit:
is something wrong with him?
PostPosted: Wed Oct 14, 2009 5:18 pm     Reply with quote
It worked for me. I changed the software in the 18F2580 test code,
http://www.ccsinfo.com/forum/viewtopic.php?t=40202&start=22
so that the #use delay() was 4 MHz instead of 20 MHz.
Check your connections and make sure you compiled the software
separately for board #1 and board #2. Make sure you know how
to do that. Make sure your RS232 cable is connected to board #1.
ivrj
PostPosted: Thu Oct 15, 2009 8:09 am     Reply with quote
I get other 2 20mhz crystal, changed back to the original code and changed delay to 20000000, but isn't working.
Does your schematic represent real hardware ? Because, there is no
MCLR circuit. There are no 100 nF ceramic caps on the Vdd pins on any
chip. Also, I would jumper the Rs pins on the MCP2551 chips to ground
for the inital tests.
where I connect the 100nF ceramic capacitors?
ivrj
PostPosted: Thu Oct 15, 2009 8:19 am     Reply with quote
Error found!
I crossed the can-l can-h lines!
now it´s working fine!
Thank u PCM!!!!
takyonxxx
MCP2551 ISIS LIBRARY
PostPosted: Fri Mar 11, 2011 7:47 am     Reply with quote
HELLO..
I NEED MCP2551 ISIS LIBRARY, I SAW FROM THE PICTURE THAT YOU USE IT ON PROTEUS. PLEASE I NEED IT. MAY YOU SEND IT TO ME?
OR GIVE ME A LINK.
THANKS...
Page 3 of 3
