PIC16F1936 watchdog enable issue
gpacer68
PostPosted: Sat Aug 29, 2009 3:21 pm     Reply with quote
I am using PIC16F1936 with compiler version: v4.098 of PCW IDE.
I am having trouble getting the watchdog chip function to work as one would expect.
I have attached code below that essentially should boot, print a start message, then a few dots and finally after about 2.3 seconds restart the PIC given that restart_wdt() is commented out. Unfortunately, this never happens. I have spent hours worth of iterating on changing fuse bits and setup_wdt function parameters and all results are the same - the watchdog never times out.
#include <16F1936.h>
#include <stdio.h>
#fuses noDEBUG   //  debug - in circuit debugger enabled on RB6 and RB7 - DISABLED
#fuses noLVP     //  LVP - low voltage enable - DISABLED
#fuses noFCMEN   //  Fail safe clock monitor - DISABLED
#fuses noIESO    //  IESO - internal / external switch over DISABLED
#fuses noBROWNOUT  //  Brown out reset selection bits - 11 BOR  DISABLED
#fuses noCPD     //  CPD - date code protect DISABLED
#fuses noPROTECT //  CP - code protect DISABLED
#fuses MCLR      //  MCLRE - RE3 is MCLR
#fuses noPUT     //  PWRTE - power up timer enable bit DISABLED
#fuses WDT_SW    //  WDTE - watch dog enable bit - not enabled here, in code below
#fuses INTRC_IO   //  FOSC - oscillator - set to INTRC_IO-- defaults the clock to 4Mhz
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7)
main()
  int b;
  printf("start\n\r\n\r");
  delay_ms(2000);
  setup_wdt(WDT_2304MS);
  b = 0;
  while(true){
    //output_toggle(PIN_B0);
    //restart_wdt();
    putc('.');
I did find that the watchdog does fire with these settings:
#fuse WDT
  b = 0;
  while(true){
    delay_ms(1);
    restart_wdt();
    putc('.');
but when you change the delay to 1000 (or 1 sec), the part simply reboots continuously. Changing the delay to 2msec, still causes the part to reboot continuously.
I was wondering if it is possible, given that this part is so new, that compiler v4.098 support for the watchdog function of this part may not be working properly?
Or could it be my code, any help would be great :-)
gpacer68
PostPosted: Sun Aug 30, 2009 1:17 pm     Reply with quote
I don't see the compiler writing to the WDTCON register in the .LST file
when setup_wdt() is called.
Make a little test program to do an experiment. See below.
In the start-up code, it disables the Watchdog by clearing the WDTCON
register. Then I have it write to the LATA register, to force it to switch to
Bank 2. Next, I write to WDTCON, as defined in a #byte statement. This
shows that the compiler will select Bank1 and then write to WDTCON at
address 0x17, and do it correctly.
Now examine the .LST code for setup_wdt(). I don't ever see it access
0x17, either directly or indirectly (with the FSR register). This is with
vs. 4.098.
// These 6 lines are the later part of the start-up code.
0019:  MOVLB  03
001A:  MOVWF  0C
001B:  MOVLB  01
001C:  CLRF   17
001D:  MOVLW  07
001E:  MOVWF  1C
.................... LATA = 0xAA;
001F:  MOVLW  AA
0020:  MOVLB  02
0021:  MOVWF  0C
.................... WDTCON = 0x55;
0022:  MOVLW  55
0023:  MOVLB  01
0024:  MOVWF  17
.................... setup_wdt(WDT_2304MS);
0025:  MOVLW  09
0026:  MOVLB  02
0027:  MOVWF  05
0028:  MOVLW  0F
0029:  MOVWF  77
002A:  MOVLB  00
002B:  CLRF   15
002C:  CLRF   05
002D:  MOVLW  81
002E:  MOVWF  04
002F:  MOVF   00,W
0030:  ANDLW  F0
0031:  IORLW  07
0032:  MOVWF  00
0033:  CLRWDT
0034:  MOVF   00,W
0035:  ANDLW  F7
0036:  BTFSC  77.3
0037:  ANDLW  F0
0038:  IORWF  77,W
0039:  MOVWF  00
.................... while(1);
003A:  GOTO   03A
#fuses INTRC_IO, NOLVP, WDT_SW
#byte WDTCON = 0x97
#byte LATA =  0x10c
main()
LATA = 0xAA;
WDTCON = 0x55;
gpacer68
PostPosted: Mon Aug 31, 2009 6:55 pm     Reply with quote
Thanks for the reply. I guess I am not following your reply. You are showing that when setup_wdt is called it does not write to 0x17 WDTCON. But then you write a test program that forces it to write to WDTCON and it works. So does this prove what I am saying in that the compiler does have a bug as it does not setup the watchdog init register properly? If so when can the compiler be fixed?
gpacer68
PostPosted: Mon Aug 31, 2009 7:19 pm     Reply with quote
This is NOT CCS Support. This is simply a user forum that is not usually monitored by CCS therefore no one here can tell you when it will be fixed. Read the box in the upper right corner of this web page then send a message with the details to CCS support at the link provided. Maybe they can tell you when it will be fixed...
PostPosted: Wed Sep 02, 2009 8:21 pm     Reply with quote
Thanks for the clarification. I am new to the forum and it looks so official I thought the site was associated with CCS. I have posted my bug report according to the instructions in the box on the top right. The forum might consider making the box outlined in RED such that it is more prominent.
Thanks again.
PostPosted: Fri Sep 04, 2009 7:17 pm     Reply with quote
perhaps it is a bit premature to expect to be able to use the new 16F1xxx
family with CCS -
about making that 'no support' box visible?
i doubt it would make a difference if it flashed in red and violet and poured coffee out of the speakers.
Very Happy
