mail send problem
maher1986
mail send problem
PostPosted: Wed Aug 19, 2009 3:42 am     Reply with quote
I use the smtp example ex 16 from ccs tcp stack.
I have a problem tcp connection can not be etablished .
Please help for this.
thanks
PostPosted: Wed Aug 19, 2009 6:08 am     Reply with quote
You'll have to provide more info.
What is your compiler version number?
What does your hardware setup look like?
Did you buy the hardware or make it yourself? If you bought it, what is the product name?
Are you using TCP/IP over ethernet or RS232?
Are you sure the hardware is OK?
Did one of the other sample programs work?
etc., etc.
PostPosted: Wed Aug 19, 2009 7:08 am     Reply with quote
The version of my compiler is ccs v4.088.
My hardware is a 18f4620 connected to enc28j60.
I make my hardware by myself.
I use CCS tcp IP stack.
All others examples of tcp/ip stack work.
I need just how can I test that the email is sent to the pc.
