Measure pulse with pic16f877
Kristian
PostPosted: Mon Apr 07, 2003 7:02 pm     Reply with quote
I've got an analogue signal that I convert to a 10 bit Digital signal. From this signal I have to find the maximum signals so I can find the Bpm. I already have found the Max and min as u can see from the code below. But I need to find the time betveen each max signal. Does this require a exsternal clock?
How can I solve this , does anyone know?
Been working on this problem way to long!
Please help me!
for(i=0;i<=500;i++)
SET_ADC_CHANNEL(0);
output_high(PIN_C0);
delay_us(2000);
value = Read_ADC();
if(value < minir)
minir=value;
if(value > maxir)
maxir=value;
output_low(PIN_C0);
SET_ADC_CHANNEL(1);
output_high(PIN_C1);
delay_us(2000);
value = Read_ADC();
if(value < minr)
minr=value;
if(value > maxr)
maxr=value;
output_low(PIN_C1);
Original Post ID: 13475
Kenny
Re: Measure pulse with pic16f877
PostPosted: Mon Apr 07, 2003 8:41 pm     Reply with quote
:=I've got an analogue signal that I convert to a 10 bit Digital signal. From this signal I have to find the maximum signals so I can find the Bpm. I already have found the Max and min as u can see from the code below. But I need to find the time betveen each max signal. Does this require a exsternal clock?
:=How can I solve this , does anyone know?
:=Been working on this problem way to long!
:=Please help me!
Here's one approach to the problem:
I think you would be better off using a system tick (generate with timer overflow interrupt) rather than use delay_us(2000).
In the overflow isr a software counter could be incremented, then when the maximum occurs the current count taken and saved, and time between successive maximums calculated.
Regards
Kenny
:= for(i=0;i<=500;i++)
:= SET_ADC_CHANNEL(0);
:= output_high(PIN_C0);
:= delay_us(2000);
:= value = Read_ADC();
:= if(value < minir)
:= minir=value;
:= if(value > maxir)
:= maxir=value;
:= output_low(PIN_C0);
:= SET_ADC_CHANNEL(1);
:= output_high(PIN_C1);
:= delay_us(2000);
:= if(value < minr)
:= minr=value;
:= if(value > maxr)
:= maxr=value;
:= output_low(PIN_C1);
Original Post ID: 13476
Kristian
Re: Thank you but.....
PostPosted: Mon Apr 07, 2003 9:52 pm     Reply with quote
This sounds just like what I need. Nut how do I do it, I've read about it now, but I still don't know how to write the code. Is there any possibility that you can help me?
Thank you so much!
Original Post ID: 13479
Kenny
PostPosted: Mon Apr 07, 2003 10:30 pm     Reply with quote
:=This sounds just like what I need. Nut how do I do it, I've read about it now, but I still don't know how to write the code. Is there any possibility that you can help me?
:=Thank you so much!
I don't have code for you, only the approach that I would try.
You need to be familiar with interrupt programming, setting flags, etc.
Here's how to setup a 1ms tick to get you started:
// The cycle time will be (1/clock)*4*t2div*(period+1)
// In this program clock=16,000,000 and period=249
// (1/16000000)*4*16*250=1000 us or 1kHz)
setup_timer_2(T2_DIV_BY_16,249,1);
// Timer2 overflow interrupt service routine
// Interrupts occur every millisecond.
#int_timer2
timer2_isr() {
//Increment software counter, set flag for main(), etc
Original Post ID: 13480
Sherpa Doug
PostPosted: Tue Apr 08, 2003 2:39 pm     Reply with quote
:=Please help me!
If you want to accurately measure the period of your input and it is anywhere close to a sinusoid you are better off using zero crossings than maximums. In the presence of noise maximums are very fuzzy while zero crossings are much more precise.
To measure period set up a timer to run as long as your longest measurement. Wait for a + to - zero crossing and set the timer to zero. Wait some small dead time to block noise. On the next + to - zero crossing read the timer to get period in counts. Repeat the measurement a few times to get an average. Do a little math to turn this period into Bpm.
Original Post ID: 13512
