How do you toggle an LED on and off using 12F509
Allen
PostPosted: Wed Dec 31, 2008 12:39 pm     Reply with quote
I want to toggle on and off an LED when I press a button, I want it to turn on when I press it and I want it to turn off when I press it again. It also has to repeat so I can do it over and over again.
If someone could please give me some code examples it would really help me out.
THANK YOU
ALLEN
PostPosted: Wed Dec 31, 2008 2:45 pm     Reply with quote
See the program below. This will flash an LED on and off. That's a good
place to start. Connect a series resistor and an LED to pin B2.
Look at Figure 5 (on page 2) of the link below to see a schematic of the
LED and resistor circuit. Do it the same way, except use pin B2 instead
of pin B0. You can use a resistor from 220 to 470 ohms. I assume your
PIC is running at +5v.
http://www.siriusmicro.com/projects/b2.pdf
Then try this program:
#include <12F509.h>
#fuses INTRC, NOWDT, NOMCLR
   output_high(PIN_B2);
   output_low(PIN_B2);
