Code forTouchscreen for Dev board easypic5 tested works fine
kabukiman85
PostPosted: Thu Oct 30, 2008 10:07 am     Reply with quote
I made this code to work with easypic5. I don't know if it is very efficient.
If anyone want to modify it to make it more efficent, please I want to know how.
thanks
      MIKROELECTRONICA ADAPTED CODE FOR CCS C
#include <16F887.h>
#device ADC = 10
#FUSES XT,NOWDT,NOPROTECT,NOPUT
#use delay(clock=8000000)
#include <GLCD_ESP5.c> // Custom library for KS108 EasyPic5
#include <graphics.c>
int16 const ADC_THRESHOLD=900;
int16 xmin;
int16 ymin;
int16 ymax;
int16 xmax;
int16 get_X()
  //Get X axis value DRIVEA = 1 DRIVEB =1
  output_c(0b00000001);
  set_adc_channel(0);
  delay_ms(2);
  return read_adc();
int16 get_Y()
   //Get X axis value DRIVEA = 0 DRIVEB =1
   output_c(0b00000010);
   set_adc_channel(1);
   delay_ms(2);
   return read_adc();
char PressDetect() {
  INT16 adc_rd;
  char result;
  // PRESS detecting DRIVEA = 0 DRIVEB = 0 read channel 1
  output_c(0x00);
  delay_us(3500);
  set_adc_channel(1);
  delay_ms(2);
  adc_rd = read_adc();
  result = (adc_rd > ADC_THRESHOLD);
  //debouncing, repeat detecting after 2ms
  delay_ms(2);
  result = result & (adc_rd > ADC_THRESHOLD);
  return result;
void calibrate_screen()
  char msg []="TOCA ABAJO IZQUIERDA";
  char msg2 []="TOCA SUPERIOR DERECHA";
  glcd_text57(0,30,msg,1,ON);
  glcd_pixel(0,63,ON);
   while(!PressDetect());
   xmin = get_X() - 10;
   ymin = get_Y() - 10;
   glcd_fillscreen(OFF);
  glcd_text57(0,30,msg2,1,ON);
  glcd_pixel(127,0,ON);
   xmax = get_X() + 5 ;
   ymax = get_Y() + 5 ;
   char msg[] = "CLEAR";
   int16 x_coord,y_coord;
   int8 x,y;
    glcd_init(ON);
   SET_TRIS_C(0b00000100);
   set_tris_b(0xff);
   setup_adc_ports(sAN0 | sAN1);
  calibrate_screen();
  glcd_rect(0,0,30,7,1,1);   //Write Clear button
  glcd_text57(0,0,msg,1,0);
      if(PressDetect())
      y_coord = Get_Y() - ymin;
      x_coord = Get_X() - xmin;
      x = (int8) ((double) x_coord * 128 / (double)(xmax - xmin));
      y = (64 -(y_coord << 6) / (ymax - ymin));
      if(x >=0 && x <=30)
         if(y>=0 && y <= 7)
         { //If clear button is pressed clear screen
               delay_ms(100); // Delay for posible stack overflow
         }else  glcd_pixel(x,y,1);
