programming 3.3V parts
Ringo42
PostPosted: Sun Oct 19, 2008 9:55 am     Reply with quote
I'm using a 16lf876a and the ICD-U40.
My board has a part (pressure sensor) that will only work at 3.3V. When I connect the programmer to the board doesn't it put 5V on the Vcc line (or require 5V be there)?
I don't want to fry the sensor by accidentally putting 5V on it. How do I program the board?
Ringo
Ringo Davis
FvM
PostPosted: Sun Oct 19, 2008 10:18 am     Reply with quote
ICD-U40 doesn't drive VCC unless you install a jumper inside the case. ICD-U40 should work with a board supply of 3.3V without problems.
