Supernova Guest
| Memory not memorised?? |
Posted: Thu Apr 24, 2008 4:23 am |
Hello i've been trying to save some data in to the flash memory but every time I restart my PIC the info is gone. Does any one know how to make the info stay?
here's my code:
| Code: | /-----------------------------------------------------------------
//Declaration de librairie
#include "test.h"
#include "Flex_LCD.h"
//Prototypes
//Déclaration de constante
#define ROM_ADDR 0x4000
//Déclaration de variables globales
//Interuptions
#INT_EEPROM
void Test_ecriture(void)
printf(lcd_putc,"\fEcriture effectué");
//- Programme Principale
//Déclaration des variables locaux
int8 i;
int8 write_data[5] = {1,2,3,4,5};
int8 read_data[5] = {0,0,0,0,0};
lcd_init();
printf(lcd_putc,"\fFlash write size = \n%u", getenv("FLASH_WRITE_SIZE"));
delay_ms(2000);
// Read flash memory.
read_program_memory(ROM_ADDR, read_data, sizeof(read_data));
// Display it, to show it's erased.
printf(lcd_putc,"\fBefore \n ");
for(i = 0; i < sizeof(read_data); i++)
printf("%X ", read_data[i]);
delay_ms(2000);
// Erase flash memory.
erase_program_eeprom(ROM_ADDR);
printf(lcd_putc,"\fFlash memory \n ");
delay_ms(2000);
// Now write 8 bytes.
write_program_memory(ROM_ADDR, write_data, sizeof(write_data));
// Read them back.
// Display data read from Flash memory.
printf(lcd_putc,"\fAfter being written: \n");
printf(lcd_putc,"%X ", read_data[i]);
delay_ms(2000);
test.h
| Code: | #include <18F452.h>
#use rs232(baud=115200,parity=N, xmit=PIN_C6, rcv=PIN_C7,bits=8,stream=sortie)
#use i2c(master,sda=PIN_C4,scl=PIN_C3,SLOW)
Matro Guest
Posted: Thu Apr 24, 2008 4:33 am |
Add the "NOWRT" in your fuses.
And as a test, try to replace :
by :
write_program_memory(ROM_ADDR, write_data, 8);
Because I'm not sure that sizeof() applied on a pointer will give the expected result.
Matro |
RLScott
| Re: Memory not memorised?? |
Posted: Thu Apr 24, 2008 5:10 am |
| Supernova wrote: |
The comment says "Now write 8 bytes, but the array, write_data[] is declared with just 5 bytes. So sizeof(write_data) will equal 5.
Robert Scott
Real-Time Specialties |
Supernova Guest
Posted: Thu Apr 24, 2008 5:20 am |
Well thanks a lot for the answers, i've tryed both options you've proposed but still it doesn't write in the flash.
It writes it once while it runs, but as soon as I stop it and restart it, the datas are gone... :( |
Matro Guest
Posted: Thu Apr 24, 2008 5:27 am |
Did you posted the whole code or are there other pieces of code (like a bootloader)?
Matro |
Supernova Guest
Posted: Thu Apr 24, 2008 5:33 am |
| This is all I have, a part from the flex_lcd.h witch is not used to save in the memory but just to print what i've read... |
Matro Guest
Posted: Thu Apr 24, 2008 6:25 am |
Could you add a print() just after the write in the flash that will display the WRERR bit?
Matro |
Supernova Guest
Posted: Thu Apr 24, 2008 6:42 am |
I get 10000100
| Quote: | WRERR: FLASH Program/Data EE Error Flag bit
1 = A write operation is prematurely terminated
(any RESET during self-timed programming in normal operation)
0 = The write operation completed
Note: When a WRERR occurs, the EEPGD and CFGS bits are not cleared. This allows
tracing of the error condition.
And it is at 1 so what can I do? |
Matro Guest
Posted: Thu Apr 24, 2008 7:02 am |
I suppose that you display EECON1, so WRERR isn't 1. That's bit 3 so its value's 0.
The write cycle is correctly done.
If you have an ICD, you can execute your program and then connect to the device and read program memory to check that the write has been done.
Matro |
Supernova Guest
Posted: Thu Apr 24, 2008 8:33 am |
Problem solved.
I used the function write_program_eeprom instead of the other ones.
It works much better now.
Thanks anyway for the help. |
Posted: Thu Apr 24, 2008 9:06 am |
I tried your original code (without LCD functions) in the MPLAB simulator and it worked without problems.
What is your compiler version? |
Supernova Guest
Posted: Fri Apr 25, 2008 1:32 am |
| it's ccs 3.2222 |
Posted: Fri Apr 25, 2008 7:37 am |
I'm guessing 3.222. The versions only ever reached 3.249, so 2222, is rather high!. If so, then this is the problem. The read and write program memory functions were only introduced at around the 3.200 level, and the early versions had some problems. There were some threads here about these at the time (about spring 2005).
