arunb
| USB access using PIC and VB |
Posted: Wed Mar 26, 2003 7:57 am |
Is it necessary to make a device driver for USB based applications, at present I am using the RS 232 port for communications. (PIC 16F628 and PIC 16F877 )
I understand I need to go in for another PIC that has a USB controller which is alright with me.
The software I am using is MPLAB/MPASM and Microsoft Visual Basic 6.0.
Do I need additional software to develop USB based applications.
Thank you
Arun
___________________________
Original Post ID: 13084 |
Lance Lascari Guest
| Re: USB access using PIC and VB |
Posted: Wed Mar 26, 2003 8:07 am |
As others have recommended, ftdi has some neat USB products. I'm currently working on a project with one of the '245 parallel fifos. They provide drivers and some example programs using the drivers on the PC (they have VB, VC++, and many more examples).
You could use these chips with pretty much any micro. I elected to buy a module with the chip mounted on it (and the usb connector) for quick prototyping. 'twas only $40 from saelig. The chips themselves are only a few dollars and have some neat features. Check them out at the link provided.
<a href="http://www.ftdichip.com/" TARGET="_blank">http://www.ftdichip.com/</a>
Lance
:=Hi,
:=Is it necessary to make a device driver for USB based applications, at present I am using the RS 232 port for communications. (PIC 16F628 and PIC 16F877 )
:=I understand I need to go in for another PIC that has a USB controller which is alright with me.
:=The software I am using is MPLAB/MPASM and Microsoft Visual Basic 6.0.
:=Do I need additional software to develop USB based applications.
:=Thank you
:=Arun
Original Post ID: 13086 |
bean Guest
Posted: Wed Mar 26, 2003 1:48 pm |
:=Hi,
:=Thank you
:=Arun
Jan Axelson has a good book on USB called "USB Complete". She also has a good website with sample PIC code and sample VB code.
<a href="http://www.lvr.com/usbcode.htm" TARGET="_blank">http://www.lvr.com/usbcode.htm</a>
Original Post ID: 13104 |
Hans Wedemeyer Guest
Posted: Thu Mar 27, 2003 4:10 pm |
I second this.
FTDI will give you the fastest speed, whereas many other designs use a HID driver which typically do not have much data through put.
Currently I'm do a 4 channel USB 12 ADC and should approach the maximum of about 1 Mega BYTE /second . I doubt the other approach would allow me to get hat kind of speed.
Also the FTDI drivers are easy to use and free.
Original Post ID: 13159 |
arunb
Posted: Sat Mar 29, 2003 8:50 am |
:=Hi,
:=Thank you
:=Arun
Hi All,
Thanks a lot for the information.
Arun
Original Post ID: 13228 |
