Verifying code protected data with the ICD
j_girl
PostPosted: Wed Aug 16, 2006 3:08 pm     Reply with quote
I am using two micros, the PIC18F6722 and the PIC18F4550. I am trying to code protect them. I used #fuses PROTECT and verified in the .lst file that configuration word 5 shows PROTECT. When I compile it and download it with CCS's ICD it runs through writing the data and verifying. I would expect, if the code is truly code protected, that the ICD would not be able to verify the code. However, it says it successfully verifies the code. Is my code truly not code protected or is there something wrong with the ICD. Confused
Thanks,
j_girl
PostPosted: Wed Aug 16, 2006 3:37 pm     Reply with quote
I think I can take this one,
If I remeber right the code verify uses the hash of the block it reads. So it doesn't have access to the data, just the hash of whats in there. So it ca verify it, without having to read it.
I might be wrong, but I think I remember reading that somewhere
PostPosted: Wed Aug 16, 2006 5:53 pm     Reply with quote
I programmed a 16F877 with the PROTECT fuse enabled, with an ICD2
in MPLAB. It gives a progress report of the programming operations.
You can see that it programs the Program Memory first and then verifies
it. Then it does the Config Memory (and sets the PROTECT fuse) and
verifies that. There's no hashing involved. It just does things in the
proper sequence.
Programming Target...
...Validating configuration fields
...Erasing Part
...Programming Program Memory (0x0 - 0x76)
Verifying...
...Program Memory
...Verify Succeeded
Programming Configuration Bits
.. Config Memory
Verifying configuration memory...
...Verify Succeeded
...Programming succeeded
MPLAB ICD 2 Ready
The sequence above happens when the PIC is programmed.
If I try to do a separate verify operation after the chip is programmed,
then MPLAB gives me an error message, as expected:
ICD0161: Verify failed (MemType = Program, Address = 0x0, Expected Val = 0x3000, Val Read = 0x0)
j_girl
PostPosted: Thu Aug 17, 2006 1:41 pm     Reply with quote
Thanks!
