not enough RAM?
sheing3003
not enough RAM?
PostPosted: Thu Aug 17, 2006 4:19 pm     Reply with quote
Hi, I'm using PIC16F877A and when i do something like
char something[100] then it'll show error, not enough RAM, hmmm any suggestion on what else I can try? Because I'm trying to store data that's 101*128 bytes, and if I send it every time to PC then putc is too slow, so I don't know what else I can do.
Thanks in advance.
PostPosted: Thu Aug 17, 2006 5:21 pm     Reply with quote
In CCS, the largest array size is limited by the RAM bank size.
For the 16F877A, the largest possible array is 96 bytes. The compiler
will place it in one of the upper banks (bank 2 or 3). You need to
enable use of all ram with the "#device *=16" statement, in order to
get the compiler to use RAM in these banks.
#include <16F877A.H>
#device *=16    // This enables use of all RAM.
#fuses XT, NOWDT, PROTECT, BROWNOUT, PUT, NOLVP
char array[96];   // This is the largest array size.
Can you explain this some more ? What type of data is being stored ?
Where does it come from ?
