Mark
Posted: Tue Mar 08, 2005 11:13 am |
Alright, I paid my yearly dues and this is what I get with 3.221
Quote: |
Clean: Deleting intermediary and output files.
Clean: Deleted file "t1.HEX".
Clean: Done.
Executing: "C:\Program Files\PICC\3221\Ccsc.exe" t1.c +FH
Executing: "C:\Program Files\PICC\3221\dummy.BAT" "C:\t1.HEX" /o "t1.HEX"
Skipping Link Step
Loaded C:\t1.COD
BUILD SUCCEEDED: Tue Mar 08 12:11:00 2005
Can't think it could be source related but if you want to post your test code I will try and compile it. |
guest Guest
Posted: Tue Mar 08, 2005 12:12 pm |
Well, my actual source code is a few thousand lines long, so I tried the simple code below:
Code: | #include "18F8720.h"
#use delay(clock=3686400)
#use rs232(baud=2400, xmit=PIN_C6, rcv=PIN_C7, parity=N, bits=8, errors)
printf("TEST");
and guess what? IT WORKS! (see below)
Quote: | Clean: Deleting intermediary and output files.
Clean: Deleted file "test.HEX".
Clean: Done.
Executing: "C:\Program Files\PCH_3221\Ccsc.exe" test.c +FH +p +t
Executing: "C:\Program Files\PCH_3221\dummy.bat" C:\TEST\test.HEX" /o "TEST.HEX"
Skipping Link Step
Loaded C:\TEST\TEST.COD
BUILD SUCCEEDED: Tue Mar 08 17:56:25 2005[/code] |
I'll now try to comment out my source bit by bit (punn intended) to find out what's causing it. I'll come back when I've found it...
Again, many thanks for all your help, Mark. This setup will make my life a lot easier. |
Mark
Posted: Tue Mar 08, 2005 12:52 pm |
Give me an email address. I have a wrapper EXE that I created for the older compiler. It may do the job for you. |
guest Guest
Posted: Wed Mar 09, 2005 4:04 am |
Thanks for the file, unfortunately still the same problem as before. I'll let you know what it was when I've found the solution. |
Mark
Posted: Wed Mar 09, 2005 7:10 am |
If you want to email me the code to try, I will test it for you. |
