guest Guest
Posted: Mon Mar 07, 2005 9:32 am |
tried it ... still no luck. :-(
Do I perhaps need to have a linker (*.lkr) script?
I am not very familiar with linkers. |
Mark
Posted: Mon Mar 07, 2005 9:33 am |
No linker script. Did you restart MPLAB after you made the changes? |
guest Guest
Posted: Mon Mar 07, 2005 9:37 am |
Yepp, every time.
No need to reboot though or is there? |
Mark
Posted: Mon Mar 07, 2005 10:17 am |
You probably didn't get a unique GUID for one of the tools and it is using the wrong INI or mtc file. Delete the registry entries that you made and then make the following into "addtool.reg" file
Quote: |
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microchip\MPLAB IDE\Legacy Language Suites\{489322ed-251d-4d29-bba5-5bb74dafd28c}]
@="TLPCH3221.ini"
"DoNotLoad"=dword:00000000
[HKEY_LOCAL_MACHINE\SOFTWARE\Microchip\MPLAB IDE\Legacy Language Suites\{489322ed-251d-4d29-bba5-5bb74dafd28c}\Tools]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microchip\MPLAB IDE\Legacy Language Suites\{489322ed-251d-4d29-bba5-5bb74dafd28c}\Tools\{BED0F566-62C2-4e1d-81DE-939BD7CD00F3}]
@="PCH3221.mtc"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microchip\MPLAB IDE\Legacy Language Suites\{489322ed-251d-4d29-bba5-5bb74dafd28c}\Tools\{BED0F566-62C2-4e1d-81DE-939BD7CD00F3}\{C8A22AE3-3335-4031-A6D5-386565A737DC}]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microchip\MPLAB IDE\Legacy Language Suites\{489322ed-251d-4d29-bba5-5bb74dafd28c}\Tools\{eae4e6f3-501b-48f3-aaa3-4ee51a9204f5}]
@="MPLINK.MTC"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microchip\MPLAB IDE\Legacy Language Suites\{489322ed-251d-4d29-bba5-5bb74dafd28c}\Tools\{eae4e6f3-501b-48f3-aaa3-4ee51a9204f5}\{42a20e31-236e-47fb-851a-fd464985044b}]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microchip\MPLAB IDE\Legacy Language Suites\{489322ed-251d-4d29-bba5-5bb74dafd28c}\{AD07CB5B-44AA-4365-9AB6-86056022DA44}]
Double click the file and it should import the data. Restart MPLAB and tell me what happens. |
guest Guest
Posted: Mon Mar 07, 2005 11:07 am |
1. I backed up and then removed my two registry keys (the ones I had added originally with incremental key names similar but not the same as the orginal tlccs.in). All other names (tools, etc) had incremental names as well so I am pretty sure there were no duplicates. I had duplicates originally when I played with it which messed things up in MPLAB ;-)
2. I then added your new keys as per your latest post
3. rebooted and restarted MPLAB.
==> Unfortunately still no joy, exactly the same 'result' as before
what setup do you have to make it work?
btw I am really appreciating the time you put in to help. |
Mark
Posted: Mon Mar 07, 2005 11:47 am |
I made a goof in one thing I told you
It should be
You can try that and see if it works. I did another test from scratch. Here is the data:
For the registry file:
[HKEY_LOCAL_MACHINE\SOFTWARE\Microchip\MPLAB IDE\Legacy Language Suites\{489322ed-251d-4d29-bba5-5bb74dafd28d}]
@="TEST.ini"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microchip\MPLAB IDE\Legacy Language Suites\{489322ed-251d-4d29-bba5-5bb74dafd28d}\Tools]
Suites\{489322ed-251d-4d29-bba5-5bb74dafd28d}\Tools\{BED0F566-62C2-4e1d-81DE-939BD7CD00F4}]
@="TEST.mtc"
Suites\{489322ed-251d-4d29-bba5-5bb74dafd28d}\Tools\{BED0F566-62C2-4e1d-81DE-939BD7CD00F4}\{C8A22AE3-3335-4031-A6D5-386565A737DD}]
Suites\{489322ed-251d-4d29-bba5-5bb74dafd28d}\Tools\{eae4e6f3-501b-48f3-aaa3-4ee51a9204f5}]
@="MPLINK.MTC"
Suites\{489322ed-251d-4d29-bba5-5bb74dafd28d}\Tools\{eae4e6f3-501b-48f3-aaa3-4ee51a9204f5}\{42a20e31-236e-47fb-851a-fd464985044b}]
Suites\{489322ed-251d-4d29-bba5-5bb74dafd28d}\{AD07CB5B-44AA-4365-9AB6-86056022DA45}]
test.ini
Quote: |
// Microchip Language Tools Configuration File
// CCS Language Suite
[Language_Suite]
LanguageSuite=Test for CCSC C Compiler
DefaultFilename=default.ht
Object=HEX
Target=HEX
Library=LIB
Source=C
Header=H
LkrScripts=
Output=LST;ERR;SYM;HEX;TRE
Debug=COD;COF
MTC_Files=test;mplink
test.mtc
// CCS PIC C
[Tool]
Tool=Test for CCSC
SourceExtension=c
HeaderExtension=h
MultipleNodes=0
[0]
Description=Test for CCSC
OptionList=PCH
Default=PCH
PCB=+FB
PCM=+FM
PCH=+FH
Data=0
MultipleOptions=0
[1]
Description=Pause after compile
Switch=+p
Data=0
[2]
Description=Generate Call Tree
Switch=+t
Data=0
Try this and see what you get. |
guest Guest
Posted: Mon Mar 07, 2005 12:31 pm |
Hi Mark,
I tried out COF instead of COFF: no change
I then created the new files test.mtc and test.ini and put them in the C:\Program Files\Microchip\Third Party\MTC Suites directory.
Next I added yor new 'test' keys to the registry.
Now I only have 2 CCS tool suites:
- the original 'CCS C Compiler for PIC12/14/16/18'
- the latest new 'Test for CCS C Compiler'
(the 'other' CCS compiler key was overwritten earlier and is now absent. I don't think this matters though - correct me if I am wrong.)
I rebooted to make the registry entries active and then restarted MPLAB, set the new language suite to 'Test for CCS C Compiler' and chose the correct exe/bat files for the 'Test for CCS C' and 'MPLINK' respectivily.
Tried a compile and ... still the same results as before. :-(
1. Is it worth reinstalling MPLAB, or downgrade to 7.00 from 7.01?
2. Do I need to clean the registry if MPLAB leaves anything behind after an uninstall?
3. Do I need to tick any boxes within the Build option, Project, MPLINK tab e.g. map file etc. ? |
drolleman Guest
Posted: Mon Mar 07, 2005 1:10 pm |
i have installed and working 2 diffrent versions of ccs pch 3.221 and pcm 2.184. this is how i set it up
installed pcm into d:\pic16
installed pch into d:\pic18
installed the latest mplab 7.01
ccs's mplab plugin
when i compile a project with pcm (the previos build was with pch) it will notice a previous change and will ask witch compiler i would like to use pcm or pch |
guest Guest
Posted: Mon Mar 07, 2005 2:19 pm |
Hi drolleman,
Thanks for your input.
I am trying to run two different versions of PCH from within MPLAB, one production version and one up-to-date version.
That's why Mark's approach is a great and neat way of achieving this. I just wish I knew why it is not working on my machine.
Maybe you and/or someone else can give Mark's method a try and report back to this thread.
Thanks |
Mark
Posted: Mon Mar 07, 2005 2:57 pm |
guest wrote: | Hi Mark,
Don't know why your other ones are gone. I chose a different GUID than any other that I posted and also changed the file name. I followed all the steps and it works fine for me on 2 different machines on both 7.00 and 7.01. |
Mark
Posted: Mon Mar 07, 2005 6:11 pm |
I guess one other thing comes to mind. Does it create the main.hex, main.cod or main.cof files? |
guest Guest
Posted: Tue Mar 08, 2005 7:21 am |
Mark, from your post: "Don't know why your other ones are gone." (referring to the CCS registy key)
Sorry, they weren't actually gone, just not loaded as I had changed the DoNotLoad value from 0 to 1 (in the registry) to stop them appear in the toolsuite select box in MPLAB.
After playing with it a bit more I have now done a clean reinstall of MPLAB 7.01. As per your post I have then added test.ini, test.mtc and added the corresponding key to the registry.
However still no luck...
On the posiive side it does generate main.hex plus either the main.cos (default) or main.cof (using the +DF command line paramter) .
I can then import the hex file into MPLAB and program the chip with my ICD2 from within MPLAB.
To summarise, it compiles fine, just isn't telling MPLAB about the newly generated hex file. Soooo close ;-)
In the test .ini file I have played with various settings like debug=COD;COF, debug=COD, debug=COF or debug=<empty>
This does not appear to make any difference... |
Mark
Posted: Tue Mar 08, 2005 7:39 am |
Try and watch the Popup compile window and the Build Tab at the same time. The Popup should disappear before the dummy.bat file is called. See if you can determine if this is correct. I had a problem with really old (version2.7XX) versions that immediately return after calling them. Since the compiling was still continuing the process would fail since there was no output. So I am thinking that if MPLAB thinks the compile process is complete but the COF or COD file is not written yet, you might get what you are seeing. |
guest Guest
Posted: Tue Mar 08, 2005 8:42 am |
Your explanation makes sense, though I don't think it is the problem I am seeing:
I removed the command line parameter +p so that the compile popup window would close straight away and it looks to me as if this compile window closes followed by dummy.bat starting. It's fast changing but that's my impression.
Which version of pch do you use? |
Mark
Posted: Tue Mar 08, 2005 9:26 am |
The latest I have is 3.217. |
