integer of 24bit
prayami
integer of 24bit
PostPosted: Tue Dec 28, 2004 3:04 pm     Reply with quote
Hi...Anybody have idea about int24 ?
I want to handle the value upto 24bit. But instead of 24bit
wright now I have used 32bit variable int32.
I got enough memory. But the problem is, I am using the int32
variable in side interrupt. And it is very necessary for me to reduce
the time of the ISR.
What should I do to use variable like int24 ?
Is it possible?
If it is possible to create int24 then can it be useful to reduce the
execution time of my interrupt?
Thanks in advanced....
Regards
Prashant
PostPosted: Tue Dec 28, 2004 4:09 pm     Reply with quote
When you are only using addition and subtraction there is not much difference in using 24-bit or 32-bit. When using multiply and division there is some optimization possible, but I guess this will not save you a lot.
Code examples can be found at www.piclist.org
Without knowing more about your code it is hard to give any hints and tips on speed optimization.
If possible, can you post your interrupt routine?
If yes, then also answer the following questions:
- How many interrupts per second?
- Which processor?
- What clock speed?
- Are there other interrupts running as well?
