Driver for 84x48 TCM8448A GLCD (ST7541 cntllr)
PICoHolic
PostPosted: Thu Feb 05, 2009 6:40 am     Reply with quote
#ifndef  TCM8448A_H
#define  TCM8448A_H
// signals
#bit  A0 =  PORTB.0
#bit  CS =  PORTB.1
#bit  RSET= PORTB.2
// commands
#define  NOP      0x00
#define  FUNCSET  0x20
#define  DISPCNT  0x08
#define  YADDRSS  0x40
#define  XADDRSS  0x80
#define  BIASSYS  0x10
#define  V0VOLTG  0x80
#define  PD       0x04
#define  V        0x02
#define  H        0x01
#define  DISPBLNK 0x00
#define  DISPNORM 0x04
#define  DISPAON  0x01
#define  DISPINV  0x05
// GLCD RAM image
BYTE GLCDRAM[6][84];
#define  GLCD_WIDTH  84
// Function to write commands
void glcd_WriteCommand(unsigned int8 C)
   A0 = 0;  //command
   delay_cycles(1);
   CS = 0;
   delay_cycles(1);
   spi_write(C);
   delay_cycles(1);
   CS = 1;
// Function to write data
void glcd_WriteData(unsigned int8 D)
   A0 = 1;  //data
   delay_cycles(1);
   CS = 0;
   delay_cycles(1);
   spi_write(D);
   delay_cycles(1);
   CS = 1;
// GLCD initialization; should be called before any other opreation
void glcd_init()
   unsigned int8 i,j;
   setup_spi(SPI_MASTER|SPI_XMIT_L_TO_H|SPI_L_TO_H|SPI_CLK_DIV_4);
   RSET = 1;
   delay_ms(1);
   glcd_WriteCommand(FUNCSET | V |H);
   glcd_WriteCommand(BIASSYS | 0x04);
   glcd_WriteCommand(V0VOLTG | 0x70);
   glcd_WriteCommand(FUNCSET);
   glcd_WriteCommand(DISPCNT | DISPNORM);
   glcd_WriteCommand(XADDRSS | 0x00);
   glcd_WriteCommand(YADDRSS | 0x00);
   delay_cycles(1);
   //clear display:
   for (i=0;i<6;i++)
      for(j=0;j<84;j++)
         glcd_WriteData(0x00);
         GLCDRAM[i][j] = 0x00;
// function to draw a pixel at a specific location and color
void glcd_pixel(unsigned int8 x, unsigned int8 y, int1 color)
   unsigned int8 yo;
   yo = y/8;
   if (color)
      bit_set(GLCDRAM[yo][x], y%8);
      bit_clear(GLCDRAM[yo][x], y%8);
   glcd_WriteCommand(XADDRSS | x);
   glcd_WriteCommand(YADDRSS | yo);
   glcd_WriteData(GLCDRAM[yo][x]);
#endif
