Can't get to work the UART in PIC16f877
Jean_Paul
PostPosted: Tue Jul 13, 2004 8:55 am     Reply with quote
Hi guys
I used the pic16f873 for my project then I change the program to compile for my pic16f877a just the header but I can't get to work my uart on the pic16f877a. I sense the output and I read 0v all the time. what is happening.
My code is the following:
#include "E:\pictest\acelerometro877.h"
#include <stdio.h>
#include <string.h>
#define ADXL210_SCALING_FACTOR 10
void accelerometer_isr(void);
void accelerometer2_isr(void);
void accelerometer_init(signed int32 zerog, long ppg);
signed long accelerometer_read(void);
//global vars used to calculate G
long adxl_t1, adxl_t2,ad1,ad2;
long adxl2_t1, adxl2_t2,a2d1,a2d2;
short adxl_waiting_for_fall;
short adxl2_waiting_for_fall;
//global vars used calibrate
signed int32 adxl_zerog;
long adxl_ppg;
long ax1,ax2,a1x1,a1x2;
Union FTOB {
int8 b[2];
long lg;
void sendlong (union FTOB value) {
int count;
value.lg=ax1;
putc(value.b[1]);
putc(value.b[0]);
void sendlong1 (union FTOB value) {
int count;
value.lg=ax2;
putc(value.b[1]);
putc(value.b[0]);
void sendlong2 (union FTOB value) {
int count;
value.lg=a1x1;
putc(value.b[1]);
putc(value.b[0]);
void sendlong3 (union FTOB value) {
int count;
value.lg=a1x2;
putc(value.b[1]);
putc(value.b[0]);
#int_CCP1
//CCP1_isr()
void accelerometer_isr(void) {
static long adxl_last_rise;
if(adxl_waiting_for_fall) {
adxl_t1=CCP_1-adxl_last_rise;
setup_ccp1(CCP_CAPTURE_RE);
adxl_waiting_for_fall=FALSE;
} else {
adxl_t2=CCP_1-adxl_last_rise;
adxl_last_rise=CCP_1;
ad1=adxl_t1;
ad2=adxl_t2;
setup_ccp1(CCP_CAPTURE_FE);
adxl_waiting_for_fall=TRUE;
#int_CCP2
void accelerometer2_isr(void) {
static long adxl2_last_rise;
if(adxl2_waiting_for_fall) {
adxl2_t1=CCP_2-adxl2_last_rise;
setup_ccp2(CCP_CAPTURE_RE);
adxl2_waiting_for_fall=FALSE;
} else {
adxl2_t2=CCP_2-adxl2_last_rise;
adxl2_last_rise=CCP_2;
a2d1=adxl2_t1;
a2d2=adxl2_t2;
setup_ccp2(CCP_CAPTURE_FE);
adxl2_waiting_for_fall=TRUE;
void accelerometer_init(signed int32 zerog, long ppg) {
adxl_zerog=zerog;
adxl_ppg=ppg;
setup_timer_1(T1_INTERNAL);
enable_interrupts(INT_CCP1);
enable_interrupts(INT_CCP2);
signed long accelerometer_read(void) { // Returns hundreths of a g
int32 value;
int8 value1;
ax1=ad1;
ax2=ad2;
a1x1=a2d1;
a1x2=a2d2;
value1 = read_adc();
putc(0xaa);
sendlong(ax1);
sendlong1(ax2);
sendlong2(a1x1);
sendlong3(a1x2);
putc(value1);
value = adxl_t1 ;
return(value);
int value;
signed int32 value1;
float value4;
port_b_pullups(TRUE);
setup_adc_ports(AN0);
setup_spi(FALSE);
setup_counters(RTCC_INTERNAL,RTCC_DIV_1);
accelerometer_init(50,4);
do {
set_adc_channel(0);
value1=accelerometer_read();
output_b(value);
} while (TRUE);
and the header:
#include <16F877A.h>
#device adc=8
#use delay(clock=20000000)
#fuses NOWDT,HS, PUT, NOPROTECT, NODEBUG, NOBROWNOUT, NOLVP, NOCPD, NOWRT
Please give me suggestions
rwyoung
PostPosted: Tue Jul 13, 2004 9:53 am     Reply with quote
int value;
float value4;
setup_spi(FALSE);
do {
set_adc_channel(0);
output_b(value);
} while (TRUE);
You are reading your data into "value1" but writing out the variable "value". If "value" was not initialized and so may well be zero all the time.
Rob Young
The Screw-Up Fairy may just visit you but he has crashed on my couch for the last month!
